Bleeding diesel fuel system
/ Bleeding diesel fuel system #1
1drobi
Middle, ct
Ford
Stupidly ran my Ford 1700 out of fuel and haven’t Ben able to successfully bled the fuel pump and restart the engine. Have Ben opening the bleed screw on the fuel pump while cranking the starter, but no success. Just getting a little bit of pulsing foamy bubbles every time, after about 20 attempts. Any secrets to being successful?
I’ve done this before, e.g. after changing the fuel filter and it has worked pretty quickly.
/ Bleeding diesel fuel system #3
On my old Massey It has two screws. I bleed the top till no air. Then the bottom. Works perfect
/ Bleeding diesel fuel system #4
Not familiar with that vehicle, but on my RV there's a bleed screw on top of the fuel filter housing.
/ Bleeding diesel fuel system #5
If you ran it out of fuel the procedure is little more involved than just changing filters. You will also need to crack the injector lines (at least the easiest ones you can reach) open the throttle and crank the engine until you see some fuel AT the injectors. Tighten the lines and it SHOULD start after that. May take a few seconds of cranking before you see any smoke but then it should start.
/ Bleeding diesel fuel system #6
I agree with Harry after inj pump is full of fuel next loosen injector lines at injectors then engage starter. After fuel is observed at injectors then tighten inj line nuts.
/ Bleeding diesel fuel system #7
If and when you open the bleed screw at the filter, are you getting fluid? If you ran it dry, chances are sediment in the tank clogged the outlet.
Remove the line from the tank to filter and blow air into the tank.
/ Bleeding diesel fuel system #8
Just remember to loosen the fill cap first so you don't build up pressure in the fuel tank.
/ Bleeding diesel fuel system #11
If pressure builds up in fuel tank then tank vent is clogged.
True, but it depends upon the pressure applied. I omitted removal of the cap by mistake, but it needed to be said. Thanks @ruffdog.
Also, @Tx Jim, I see with over 10,000 posrs, you are a new member again!
/ Bleeding diesel fuel system #12
Several yrs ago I mistakenly got logged off this site by no fault of mine. I had to contact the site moderator to get logged back onto this site. My handle reference got changed to new member at that time & has just stuck there no matter what my post count is. It hasn't really bothered my ability to post threads so I've just ignored the fact that I have 10,317 posts as a "new member"!!;)
/ Bleeding diesel fuel system #13
Keep an eys on the time that you actually run the starter. There are very short run times followed by very long let it cool times. Burning up a starter because you failed to adhere to the duty cycle time will hurt your back pocket ALOT!
Bleeding a fuel system is never fast.
David from jax
/ Bleeding diesel fuel system #14
Some systems are easier than others. On my Case tractor, I usually just need to get the air out of a couple of injector lines, all the way up to the injectors, and then it'll fire up and clear the rest of the lines on its own. On my VW TDI, though, even AFTER getting fuel right to the injectors, you still have to crank it hard (and have a battery charger ready). I suspect air gets trapped in the injector pump. Rotary pumps are worse for that than inline pumps.
/ Bleeding diesel fuel system #15
I have a Kutkwick mower than ran dry due to clogged tank screens. After replacement, I discovered the OEM technique was messy/dangerous (using pressured air to create a venturi at the pump to pull diesel fuel into...then pump while bleeding injectors. I added a valved tap at the fuel line nearest the injectors and used a vacuum box bubbler...pulled a vacuum until fuel was bubble free...closed valve...started engine (which took about 3 seconds of cranking)...removed the temporary vacuum box bubbler & line and good to go. Now I have a quick way to refill if the operator (me) runs the engine dry.
/ Bleeding diesel fuel system #16
If you have tried everything else, you can start the engine with a gasoline-soaked rag, over the intake. This will bleed the lines faster. Make SURE you don't let the rag get sucked into the intake. Put the rag before the air filter, if possible.
This is less destructive than starting fluid, on a diesel. I have successfully used this method on engines where I didn't want to crack the lines because they were very hard to get to (cab-over box truck).
Chris
/ Bleeding diesel fuel system #17
I have had success cracking one of the fuel lines at an injector and cranking til it starts. Don't forget to tighten it.
/ Bleeding diesel fuel system #19
The fuel pump has a manual pumping lever, do not use the starter to bleed the system. Open the bleed screw and work the lever up and down until all the air is out.
/ Bleeding diesel fuel system #20
I had a 91 Ford and ran it dry many yrs ago. I got the manual out, read it and bled it, did not open any injector lines, but fail to remember what I did, though it was easy. Wish I could help, but sold that w/manual 4 yrs ago. Good luck.
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
