No fuel
/ No fuel #1
DLey
White 6105
I have a white 6105 and am getting no fuel. put in new crank sensor and new fuel governor .was not getting amp draw while cranking and has code 2 have power and ground to controller any advice is appreciated
/ No fuel #2
Does it need the filters replaced? If you take a fuel line off does fuel gravity flow out of the tank? Does it have a lift pump and if it does is it working? Does it have a fuel shutoff solenoid and is it working? Plugged out let from fuel tank? Plugged or collapsed fuel line? So many possibilities we need more info.
/ No fuel
If you take off the fuel governor you can manually move the rail and it will run.the test to check a code 2 is to check amp draw to governor should be 2amps while cranking.I am getting no amps so replaced governor still code 2 for circuit shorted or open.I have power and ground to module and voltage coming out of module.
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
Shop Cart (A68134)
Shop Cart (A68134)
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
2016 Ford F-550 Auto Crane 4004EH Service Truck (A64556)
2016 Ford F-550...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
