No fuel
/ No fuel #1
DLey
White 6105
I have a white 6105 and am getting no fuel. put in new crank sensor and new fuel governor .was not getting amp draw while cranking and has code 2 have power and ground to controller any advice is appreciated
/ No fuel #2
Does it need the filters replaced? If you take a fuel line off does fuel gravity flow out of the tank? Does it have a lift pump and if it does is it working? Does it have a fuel shutoff solenoid and is it working? Plugged out let from fuel tank? Plugged or collapsed fuel line? So many possibilities we need more info.
/ No fuel
If you take off the fuel governor you can manually move the rail and it will run.the test to check a code 2 is to check amp draw to governor should be 2amps while cranking.I am getting no amps so replaced governor still code 2 for circuit shorted or open.I have power and ground to module and voltage coming out of module.
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
48" Farm Jack (A64127)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
