New trailer
/ New trailer #1
RPK
Eastern CT
Kubota L3130 Cub Cadet 1554
I am in the market for a new trailer for my L3130 with LA 723 loader, BH 90 backhoe and loaded tires. My truck is 2001 2500HD Duramax with 6ft 6 bed.
I was considering an 18ft 9900lb trailer either PJ or Big Rex brand.
Am I on the right page. Any help would be greatly appreciated
Thanks,
/ New trailer #2
The 18' bed may place the BH really close to the edge of the tail of trailer.
From Tractordata.com - Weight: 3120 to 3305 pounds
LA 723 loader.....just guessing maybe .....1200 pounds
BH 90 backhoe using Woods info about.......850 pounds
Loaded tires about ..................................500 pounds
So looks like your on a good start and you have plenty of truck.
I would look at total length and look at the rear wheels of tractor will near or over both axles.
If not maybe a 20' trailer would be a better fit.
/ New trailer #3
I have a 20' PJ. Perfect size for my L3400 + FEL & rotary mower to load, balanced correctly. My thinking is that the 18' is a little tight for your use.
/ New trailer #4
Definitely a 20'. Any less & you'll have issues balancing it. You dont just need to fit the machine & implement(s) on, you need room to move stuff around to get proper tongue weight. My 22' is a little cramped for my L4060 with a 2nd impliment or just a longer single impliment.
You could probably get away with a 10k trailer (2 5k axles), bit I'd go for a 14k. My L4060HSTC is a hair over 5k with cab, loader & loaded tires. Your grand might be a bit lighter, but not by a lot. My flail mower is just shy of 2k. So 7k easy of load. My power tilt deckover is a bit heavier than most & is 4k itself. So 11k of load on 14k of axles gives me safety factor & breathing room. A 10k light duty trailer might only be 3k, but that would be pushing the equipment harder than you really should.
/ New trailer #5
Thanks,
As others stated...20’ for sure. I have 18’ and should have gotten 20’ 10k.
/ New trailer #6
I have a PJ 18 with tip up ramps... works great. It is a 12k trailer derated to 9980 lbs. because in California I would not be able to use with my regular license...
No harm in going longer... never know what might need transporting in the future.
/ New trailer #7
Had a 20' bumper pull low deck:
Then my first gooseneck, picture from 2002:
Bought a Gooseneck 18+4 deckover with a pop up dovetail 9-6-2006:
Still have it 13 year later, no plans to ever go back to a bumper pull.
This picture from 2015 is the latest picture I found:
/ New trailer #8
I bought my 20ft PJ trailer 14,000 lbs.about 8-9 years ago.It has served me well.I would also look at corn pro trailers.
/ New trailer
I tried to attach a picture?? The 18ft 14,000 lb derated to 9900lb Big Tex works great. Nice and solid transporting my tractor. No CT DMV hassle. They register it right at the store.
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
Box of New Take Off Agco/White Planter Parts (A65640)
Box of New Take...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2004 TRAILMOBILE 102" X 36' VAN TRAILER (A64277)
2004 TRAILMOBILE...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
