New trailer
/ New trailer #1
RPK
Eastern CT
Kubota L3130 Cub Cadet 1554
I am in the market for a new trailer for my L3130 with LA 723 loader, BH 90 backhoe and loaded tires. My truck is 2001 2500HD Duramax with 6ft 6 bed.
I was considering an 18ft 9900lb trailer either PJ or Big Rex brand.
Am I on the right page. Any help would be greatly appreciated
Thanks,
/ New trailer #2
The 18' bed may place the BH really close to the edge of the tail of trailer.
From Tractordata.com - Weight: 3120 to 3305 pounds
LA 723 loader.....just guessing maybe .....1200 pounds
BH 90 backhoe using Woods info about.......850 pounds
Loaded tires about ..................................500 pounds
So looks like your on a good start and you have plenty of truck.
I would look at total length and look at the rear wheels of tractor will near or over both axles.
If not maybe a 20' trailer would be a better fit.
/ New trailer #3
I have a 20' PJ. Perfect size for my L3400 + FEL & rotary mower to load, balanced correctly. My thinking is that the 18' is a little tight for your use.
/ New trailer #4
Definitely a 20'. Any less & you'll have issues balancing it. You dont just need to fit the machine & implement(s) on, you need room to move stuff around to get proper tongue weight. My 22' is a little cramped for my L4060 with a 2nd impliment or just a longer single impliment.
You could probably get away with a 10k trailer (2 5k axles), bit I'd go for a 14k. My L4060HSTC is a hair over 5k with cab, loader & loaded tires. Your grand might be a bit lighter, but not by a lot. My flail mower is just shy of 2k. So 7k easy of load. My power tilt deckover is a bit heavier than most & is 4k itself. So 11k of load on 14k of axles gives me safety factor & breathing room. A 10k light duty trailer might only be 3k, but that would be pushing the equipment harder than you really should.
/ New trailer #5
Thanks,
As others stated...20’ for sure. I have 18’ and should have gotten 20’ 10k.
/ New trailer #6
I have a PJ 18 with tip up ramps... works great. It is a 12k trailer derated to 9980 lbs. because in California I would not be able to use with my regular license...
No harm in going longer... never know what might need transporting in the future.
/ New trailer #7
Had a 20' bumper pull low deck:
Then my first gooseneck, picture from 2002:
Bought a Gooseneck 18+4 deckover with a pop up dovetail 9-6-2006:
Still have it 13 year later, no plans to ever go back to a bumper pull.
This picture from 2015 is the latest picture I found:
/ New trailer #8
I bought my 20ft PJ trailer 14,000 lbs.about 8-9 years ago.It has served me well.I would also look at corn pro trailers.
/ New trailer
I tried to attach a picture?? The 18ft 14,000 lb derated to 9900lb Big Tex works great. Nice and solid transporting my tractor. No CT DMV hassle. They register it right at the store.
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
2021 KUBOTA RTV-XG850 SIDEKICK RTV (A64277)
2021 KUBOTA...
Livestock Catch Chute (A66408)
Livestock Catch...
2022 EZ-GO ELITE...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
