New shop started
/ New shop started
Thx for the comments
I will look to see what controller/motor he is using. 18'x10' high lift makes for a heavy chore.
Siding is vinyl. We love the look of cedar but to maintain it on top of a large log home, forget it. Going all red and pvc painted trim to match the red gives it that 'barn' look that is good enough for me. Farmers porch out back is now up (covered storage for large towable boom lift and blacksmith area.)
Rough electrical and 3 phase rotary converter in for shops. Insulation,drywall to start soon.
More pics soon
/ New shop started
Uhoh new big shop disease
Shop isn't even done yet, new to me 10,000lbs 24.5 swing x72" monarch. Crane bolted to wall comes with it (to move steady and chucks). Fully tooled, aloris cxa, 5 chucks. Monster drills etc.better pics to follow soon once moved in a month. Also got a monster arbor press and 500lbsof broaching tooling(anyone need a key way?) also a big welding table with 2 vises etc
For reference, the headstock is nearly taller than me. The box to the left in bottom pic is a step to stand on when operating.
/ New shop started
Some pics inside today, drywall up. Few weeks away now
Track fixed
/ New shop started #45
I've never seen garage doors installed like that before. Does it require something special on the springs since the weight doesn't get reduced as much as the door raises and the spring unwinds? Seems like it would run out of lift. Also, looking at the equipment, I realize what you mean by "shop" and what the rest of us think is not the same. :thumbsup:
/ New shop started #46
VERY nice! Looking great
/ New shop started
Thx
Kenny, I'm not sure. Style is just called a high lift door. I can tell u this. With this option it is easy to hand lift the door as compared to the prior setup. The springs are massive. I would not want to mess with them.
No motor on it yet
/ New shop started #48
Every shipping dock that I've ever been on, the doors go straight up.
/ New shop started #49
Around here they almost always do roll ups. Not enough headroom for a vertical lift and they don't want the hardware sticking out into the building.
/ New shop started #50
Very nice build. I am starting mine in the next month.
/ New shop started #51
What are you going to make on the monster lathe? That's a brute!
/ New shop started
thx gn, post it up when u start
king, I have a few things in mind, first is to re-bush the front idlers on a crawler I have. I also to start The shop move in, ihave to tap/ thread a whole bunch of 10 foot lengths of iron pipe for air lines. I have a couple other lathes but this is the biggest thus far
/ New shop started
Rear view of porch for dozer storage and blacksmith area
Bit dusty but getting there
/ New shop started
Here are the pics from today, first under the overhang, storage and smith area
Paint started in automotive/fab area etc
Woodshop, door to left is access to attic for wood storage, garage door opens to main area for forklift access, dust collector pipe will come up on right side near window, through floor. Once again, dust collector home is down in metalshop in closet. I chose to just run pipe exposed, running along ceiling with drops to machines. (6 and 4" pvc.) While not as "clean" looking, I have had clogs before and I don't want to be digging up in ceiling.
/ New shop started
deere fits well under the overhang. a good place to drop off the backhoe attachment when I need to flail cut
2 crawlers and log arch will also be under there along with the blacksmith stuff
/ New shop started #57
Any operators besides yourself?
Only reason I ask is the above picture looks similar to one that the guys brother in law took out a couple of posts "Helping" out and not compensating for the loader when backing and turning.
/ New shop started
Move is done. Next is to start reorganizing, air lines and dust collection and electric/heat install.
I was a bit concerned with the "counterweights" when moving my rivett
Monarch and rest in place
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2016 John Deere 6155R (A64126)
2016 John Deere...
Tool Bar (A64127)
Tool Bar (A64127)
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
LMC 24 Row Boom Sprayer (A64126)
LMC 24 Row Boom...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
