New shop started
/ New shop started
^ thank you. a bit of planning, a bit of luck. thus far no serious faults
/ New shop started #102
Thx all
Just a hobby shop ehanson
3 phase via rotary converter tho I am working on a high voltage issue that I have run into when I started adding a vdf to a bandsaw
unless I missed it earlier, can you talk about your hobby and what you will most likely do with this machinery?
Looks like you could make a crankshaft from scratch...
please keep the pics coming
/ New shop started #103
Not to distract from the OP's thread. I met a guy couple years ago that lives about 15 miles from me. Met him at a car show where I had my offroad buggy. Started visiting with him and discovered he had a Machinist shop in his backyard. I needed a shaft built and was more than willing to have a local guy do it. I went to his place the next weekend with my old shaft. He took me into a medium sized pole barn covered with vines and tree limbs. Inside was something similar to the OP's shop. I was speechless. This guy had a great shop and is a great machinist.
So, if he just uses it for his "hobby" it's cool by me. Hopefully his neighbors will "discover" him some day. :cool:
/ New shop started
Projects vary, I like old tools, machines etc. anything rusty that needs fixing!
/ New shop started
Ok onto projects!
First project
Nice to to be tripping over myself
Plenty of room to tune up the husqvarna!
The 3320 Deere, scissorlift and 42' boom lift are also in there.the big military Clark forklift will also be in there once I address the leaky hydraulics
Next on list, 250r 3 wheeler needs rear brakes,forklift needs mast bearing,3phase needs a bit more work, another cnc to install(maybe)
List is growing...
/ New shop started
Here is what I did for some storage
The green shelf unit, most of the stock and all hardware on unit was from a machine shop going out of business, $200
This is all hidden under the stairs going up to wood shop
I also have the compressor and rotary converter in there to keep things quiet
Those were both craigslist finds also
Bike done, breaks on trike done, 3 ph is mostly worked out,bandsaw converted to vfd
Tomorrow auto lifts are to be delivered
Pics to follow
/ New shop started #107
Awesome shop. Just needs worked in. :D
/ New shop started
That bike is trying to kill me. Time to let it go. I love the bike, I love the style but wayyyy to much power for the trails I have(rock, streams etc). It is stupid fast (think cr500 power)
Will put it up in the spring once the snow clears. Maybe go with a smaller vintage 4 stroke or get another rokon
/ New shop started #110
Us old guys always blame it on the bike...... :
/ New shop started #111
I would be interested in that bike. What model? Year? Had a 76 WR360 several KTM after that. Great memories.
/ New shop started #112
Nice shop. I wouldn't wanna get it dirty............but oh how I would. Where are you located? Anywhere Willis, Texas? My local backyard machine shop closed up. I need to find a new one.
hugs, Brandi
/ New shop started #113
I gave up trail bike riding growing up in the PNW way long ago. I think the straw that broke the camel's back (luckily not mine) was when I missed a tight trail turn and flew into a big old cedar stump. Thankfully, it was logged probably 80+ years earlier and it was so rotted that I buried the bike past the handle bars and launched myself over and into a bed of mossy, ferns and decaying stuff. Softest running into a wall possible. My buddy took a few minutes to circle back and find me and then only asked where is the bike? I pointed and he squinted looking around. Pretty funny when he finally found it.
/ New shop started
1982 430 wr husqvarna
Well cared for, just a few things w bike, it will make someone happy. Someone strong that is. Kicking this beast is fun. It is left side kick to rear. Swedes must have a strong left leg! I made the left foot peg removable with a C clip so you're inside ankle doesn't get brutalized when kicking.
Runs great, Will link a video once it loads
As far as selling, this would be local only, wasn't planning on moving it till spring as I still have a soft spot for it(like a bruise!)
Rhode Island area
Ok let's see if this works
https://youtu.be/ongu4b0uSok
/ New shop started
Lifts delivered today. 52,000lb capacity (13k per column), 4 full height jack stands and attachment to frame lift from ends of vehicle(only using 2 columns to lift in that case). Lifts stand about 8' tall for perspective. Not lifting tractor to max height, just trying them out. Training tomorrow
As simple as they seem, the jack stands rock. Perspective is poor in the pic. In the extended position, as I am showing-that is about 7' off floor. Spring operated lifts at wheels(once u put weight on it settles to floor, springing up to roll easy once weight is off). Also spring assisted center column so u don't have to lift center column to position. You can set height with 2 fingers, threaded caps at end for fine adjustments.
/ New shop started #116
I look at those auto/truck/tractor lifts and just go oh my.... :dance1:
What a great way to work under your equipment. Safely too, though I think I'd check everything six times before
I walked under something that heavy.
/ New shop started #117
I was a bit paranoid when I first started using my hoist. But I pay no attention to that now. Mine is a 4 post drive-on. I think it's considerably safer than a 2 post with arms.
When was the last time you heard of someone being injured or killed by a falling hoist?
/ New shop started #118
Can you tell me a little bit more about those vertical lift Doors you have. I have never seen any quite like that. Did you custom bend the radius in the track yourself or did you order it that way?
/ New shop started
Lifts are by lift master
Doors are 18x10
Track was installed as per my design. I know when they had to correct the erroneous initial installation they had to wait for more track. I'm not sure if the bend was custom or they had something that was close. Bend is about 45deg
/ New shop started #120
Lifts are by lift master Doors are 18x10 Track was installed as per my design. I know when they had to correct the erroneous initial installation they had to wait for more track. I'm not sure if the bend was custom or they had something that was close. Bend is about 45deg
Thank you
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
John Deere 1023E (A62177)
John Deere 1023E...
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
QA Sweeper (A64126)
QA Sweeper (A64126)
2009 International 4300 Digger Derrick (A62613)
2009 International...
213138 (A64276)
213138 (A64276)
