New Member
/ New Member #1
col6365
1953 ford jubilee
Joined to get some help with a 1983 John Deere 318 I recently purchased, I want to change the engine oil and can't find drain plug. I watched some You Tube videos and all that I found had a access hole on right side of engine with a drain valve, I don't have that hole. Any help would be appreciated thank you.
/ New Member #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section to see if we can find you some advice.
/ New Member #3
col6365
:welcome: to TBN
Think you will find the plug underneath the engine.. Here is a parts drawing showing the drain plug..
/ New Member #4
:welcome: to TBN...enjoy.
/ New Member #5
:welcome:
Instead of "Vintage" this should be in JD Lawn & Garden Tractor section.
/ New Member #7
Col6365, welcome to the forum.
There is an access hole in the tractor frame on the right side just above the tie rod. Brass valve and nipple. I put a 6” long piece of tubing on the nipple, I think it’s 5/8”, and open the valve with a pair of needle nose pliers. Many revolutions till oil comes out.
/ New Member
Thanks for the help I was able to figure it out, the oil plug was replaced with an expandable rubber frost plug type. I did get it out only to find that the threads in oil pan are damaged. Looking into repair options that I can do with out pulling engine hopefully. My 318 doesn't have that extra side hole for the brass valve.
48in Farm Jack (A65583)
48in Farm Jack...
100 Manure Spreader (A66408)
100 Manure...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2000 Caterpillar V300B 30,000lb Rough Terrain Forklift (A64553)
2000 Caterpillar...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
Mayrath 30' Auger (A66285)
Mayrath 30' Auger...
