New Member
/ New Member #1
col6365
1953 ford jubilee
Joined to get some help with a 1983 John Deere 318 I recently purchased, I want to change the engine oil and can't find drain plug. I watched some You Tube videos and all that I found had a access hole on right side of engine with a drain valve, I don't have that hole. Any help would be appreciated thank you.
/ New Member #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section to see if we can find you some advice.
/ New Member #3
col6365
:welcome: to TBN
Think you will find the plug underneath the engine.. Here is a parts drawing showing the drain plug..
/ New Member #4
:welcome: to TBN...enjoy.
/ New Member #5
:welcome:
Instead of "Vintage" this should be in JD Lawn & Garden Tractor section.
/ New Member #7
Col6365, welcome to the forum.
There is an access hole in the tractor frame on the right side just above the tie rod. Brass valve and nipple. I put a 6” long piece of tubing on the nipple, I think it’s 5/8”, and open the valve with a pair of needle nose pliers. Many revolutions till oil comes out.
/ New Member
Thanks for the help I was able to figure it out, the oil plug was replaced with an expandable rubber frost plug type. I did get it out only to find that the threads in oil pan are damaged. Looking into repair options that I can do with out pulling engine hopefully. My 318 doesn't have that extra side hole for the brass valve.
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2022 EZ-GO ELITE...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 International...
