New Member
/ New Member #1
col6365
1953 ford jubilee
Joined to get some help with a 1983 John Deere 318 I recently purchased, I want to change the engine oil and can't find drain plug. I watched some You Tube videos and all that I found had a access hole on right side of engine with a drain valve, I don't have that hole. Any help would be appreciated thank you.
/ New Member #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section to see if we can find you some advice.
/ New Member #3
col6365
:welcome: to TBN
Think you will find the plug underneath the engine.. Here is a parts drawing showing the drain plug..
/ New Member #4
:welcome: to TBN...enjoy.
/ New Member #5
:welcome:
Instead of "Vintage" this should be in JD Lawn & Garden Tractor section.
/ New Member #7
Col6365, welcome to the forum.
There is an access hole in the tractor frame on the right side just above the tie rod. Brass valve and nipple. I put a 6” long piece of tubing on the nipple, I think it’s 5/8”, and open the valve with a pair of needle nose pliers. Many revolutions till oil comes out.
/ New Member
Thanks for the help I was able to figure it out, the oil plug was replaced with an expandable rubber frost plug type. I did get it out only to find that the threads in oil pan are damaged. Looking into repair options that I can do with out pulling engine hopefully. My 318 doesn't have that extra side hole for the brass valve.
2016 KENWORTH T270 SERVICE TRUCK (A62130)
2016 KENWORTH T270...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
(APPROX,9) UNUSED KJ GALVANIZED WELDED WIRE MESH (A62131)
(APPROX,9) UNUSED...
Hydraulic Bottle Jack (A61568)
Hydraulic Bottle...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
2013 Bomag BM-211D Vibratory Soil Compactor (A61567)
2013 Bomag BM-211D...
