nybirdman
Super Member
I have to agree.Had a couple close calls with the 8N's.
You are correct the PTO shaft is smaller than the standard 540 PTO shaft, you can get an adapter for it. A better solution is an over running clutch which is much safer.This link should take you to a list of the Ford N tractors, it gives descriptions and tells how they differed. Ford-Ferguson
Pay special attention to inadequacies of the hydraulic lift on all of the N series tractors.
SOMEONE PLEASE CORRECT ME IF I'M WRONG.
I believe the 9N has a smaller diameter PTO shaft, which is not standard for today's PTO equipment. Many years ago someone told me that the insert adapters did not hold up. At that moment he was buying a complete end coupler for the PTO shaft of his mower. Hopefully, these are still available.
Wow you sure have had a lot of very serious problems with the N series, I’ve been operating a 8N since I was about 10 years old and never ran into anything, its never even come close to being tipped over and when using the PTO the tractor stops like it’s supposed to.The n series tractor has one goal and purpose and that is to kill you.
If it can't kill you it wants to tear your limbs off.
If it can't do that it wants to turn over on you and it's not easy to jump off how the running boards and pedals are set up.
If it can't do that it will try to ram fences, buildings, cars, and other people's property as it's out of control.
It constantly tries to do these things while you're trying to get work done.
Get a newer tractor. Leave the Ns in the museum where they belong.
My1951 8N has a "Sherman" low range transmission, (only some of the later models do) and that helps with the ground speed issue, but no power steering is my primary complaint (I do not have a loader).Oh, also, they have low range......and steer is not an issue when moving, keeps you fit in the upper body ....
