Buying Advice New Member Looking At First Tractor - Ford (9N/8N)
   / New Member Looking At First Tractor - Ford (9N/8N) #21
   / New Member Looking At First Tractor - Ford (9N/8N) #22
Do yourself a big favor and buy a modern ish tractor with a HST trans and a loader. It would be safer and far more useful.
   / New Member Looking At First Tractor - Ford (9N/8N) #23
4wd gives you front wheel braking and traction. Really important if you have significant slopes.
   / New Member Looking At First Tractor - Ford (9N/8N) #24
   / New Member Looking At First Tractor - Ford (9N/8N) #25
I have always thought the 8N is a great first tractor! If you learn how to get work out of it and how to work on it you will be miles ahead of the game with a modern tractor. It will teach you to pay attention as you learn it's limits. Things like anticipating stops will go a long way. I hardly ever need my brakes because I started on a 8N at 6 years old.
I agree an N makes a great first tractor.
Just a few thoughts, no special order.....
The tractor in the OP is a 2N or 9N, not an 8
I used a 2N around here for 20+ years as my only and later as a back up tractor.
Tires on it when I got it were weather checked & OLD.
Same tires are still on it and it lives outside.
My 2N (pretty much the same as a 9N) has running boards & I like them.
As already mentioned, 8N has 4 speed & 2 or 9 have a 3 speed.
No power steering but with a minimal amount of grease it steers just fine.
Mine is used for maintaining my road & drive(6' back blade & 6' York rake), finish mowing (6'), brush hogging(5'), boom poll for picking up stuff, working my woods for firewood & harvesting timber, chipping brush & pretty much anything I can think of around here.
I DO have a newer 4x4 about the same size as the N and it also is used for everything.
It REALLY is nice having a backup tractor when one goes down.
For the price of a cheap riding lawnmower you have very capable machine that will last MUCH longer then that mower.
Get a N if you can find one but I wouldn't pay more ten $2k or $2500 with implements.
Use it to learn on and figure out what you need and/or want in the future.
I converted mine to 12V and am glad I did.
   / New Member Looking At First Tractor - Ford (9N/8N) #26
If he gets something without a fel and needs to move stuff he can get or build three point forks pretty cheap, or as previously stated a boom pole for even cheaper, I'm unsure of three pt lift cap on the n series though.
I am not throwing any of this info away. Its just a lot to take in. and some good stuff. All I ask is if the 9Ns are not good please explain why and pretty much all of you have given me reasons to continue my search and research.
1. I have no idea on tractor model numbers so I have no idea where to start. For now I'm going to check more into that 2110 that Airbiscuit shared.
1a. if there is a method to the madness of tractor model numbering please let me know but after learning the origins of 9N 2N and 8N. yeah Im expecting no method! LOL.
2. All things being equal I would love to have a FEL but Im just not sure we can get it in the budget.
3. I would like to for sure use this in the winter for plowing or whatever so more traction would be nice.
4. I may have 60 VERY FLAT acres but like i posted earlier most is woods with ATV trails and there are only a few acres we want to "recultivate". Please keep it coming Im not fully locked in to the N series and the slightly newer fords have me interested.
If I am going with an N im going to try and hunt down a 8N
I already have a 3 point forks found on the property. The PO had a N series tractor so it should be good to go. Also have some sort of moldboard two wheeled plow, a 10ft wide disc harrow and one of those old spike style drag frames. Not sure on name of that one still new to this.
   / New Member Looking At First Tractor - Ford (9N/8N) #29
Please enter your location in your profile, it may help one of us to help you.
   / New Member Looking At First Tractor - Ford (9N/8N) #30
A 9n is geared too high with the 3 speed for what you want to do.
The FEL can be somewhat replaced with using a pond/dirt scoop on the 3 point. It makes a good carry all also.
I have had 2n,9n,8n, and now a 64 Ford 2000. It is so much better but sets months at a time as I use my Kubota L3301.
The 9n/2n is better than doing things by hand and foot but it has been improved upon so much that they are really not the workhorse you appear you will need and another would suit you better.
You can buy a lot of tractor that would serve you better for 4K.
That FEL is nice but farmers and landowners have made do without for a lot of years.
Those implements you found on the place will probably fit other tractors. The n series used the Ferguson 3 point system that became the standard so most implements can be used interchangeably.
Look for
Massey Ferguson 35/135. Used all over the world.
Ford 600 series
John Deere but that green paint tends to be expensive.
Live PTO and at least 4 speeds or a Sherman underdrive would be a minimum requirement.
Diesel will sip fuel and will run forever. But cost more. And if they break, usually expensive.
Gas would be better for first timer.
My 2 cents.
   / New Member Looking At First Tractor - Ford (9N/8N) #31
I still have not found exactly what the improvements were on the 8N and Jubille from the 9N.
This link should take you to a list of the Ford N tractors, it gives descriptions and tells how they differed. Ford-Ferguson
Pay special attention to inadequacies of the hydraulic lift on all of the N series tractors.
SOMEONE PLEASE CORRECT ME IF I'M WRONG.
I believe the 9N has a smaller diameter PTO shaft, which is not standard for today's PTO equipment. Many years ago someone told me that the insert adapters did not hold up. At that moment he was buying a complete end coupler for the PTO shaft of his mower. Hopefully, these are still available.
Look for
Ford 600 series
My 2 cents.
I did have my eye on a Ford 640 but that sold same day posted. Green costs green for sure. I will look into that MF35. Found one with Live PTO hi lo 3spd and FEL for 4k. that was just a quick search.
I am going to look more into the Massy 35 for sure.
Posted a new thread with a lot more info on the property and what we want to do. I am now open to a bunch of ideas
   / New Member Looking At First Tractor - Ford (9N/8N) #35
I'll say it again, these look like options worth looking into.
   / New Member Looking At First Tractor - Ford (9N/8N) #36
Here’s a much more useful Ford 3910 two states south of him for $5300.
With this 3910 you get diesel, much more weight, power, reliability, traction, good rubber with diff lock, and good gearing.
Pardon Our Interruption
I toatlly agree on this only considering one model vs the other. I bought a 3910 a couple of years ago and no way can you compare the two.
   / New Member Looking At First Tractor - Ford (9N/8N) #37
Early Fords had a 1 1/8" 6 spline shaft....I think I am recalling the correct "fraction", but it was smaller than any of the implements available in later years....to date.
Later standardization was 1 3/8 and held constant over the years across the industry. The Ford Transmission driven PTO required an external PTO shaft attachment, overrun clutch for any implement that had any "stored Kinetic Energy", like a mower. These devices are available at numerous stores and if you have a 1 1/8" dia PTO shaft on your early Ford, you buy the one with that sized input.
Otherwise you can buy an adapter....1/8 to 3/8...and then the ORC, and the length of your shaft is getting to be an interconnect problem with implements.
The problem with tranny driven PTOs is that energy I mentioned, when the tractor RPMs become less than the speed of the implement, the implement keeps positive pressure on the gears of the transmission and the transmission will not disengage from the PTO nor the rear wheels..........you have the clutch pushed in but the energy in the implement becomes the driving force till it dissipates.
This "little" problem can/will/has drive/has driven tractors into anything in their path when it occurs...fences, buildings, ponds, over a cliff....you name it.
Now sir, if you were to go after that 3910 it has an Independent PTO that you can turn on or off at your discretion and it immediately disengages from the tractor's drive mechanism. Additionally when you are mowing pasture and come to a turn, or want to back up under a tree's overhanging branches, the Independent keeps running and cutting the whole time whereas, the Tranny PTO stops "finally" so that you can get the tranny to shift, get it shifted to R and upon letting out the clutch, the rear wheels start to propel you backwards, as the PtO starts turning, meaning that you are starting your cutting as you back up into the corner, not cutting the corner while you back up.......BIGGGGGG DIFERENCE!!!!
OH! The other problem with add on OHCs is that if your implement is of the drag (not 3 PT) type extending the drive shaft messes up the design of the "Constand Velocity" relationship between the drive shaft RPMs and driven shaft RPMs. This non uniform relationship adds vibration to the driveline which get progressively worse as the turning radius decreases (you make a tighter turn). If you ever had it happen you realize that you "really" don't want to be doing that!
   / New Member Looking At First Tractor - Ford (9N/8N) #38
If it hasn't been directly mentioned, I believe the N's also lacked an over running clutch on the PTO. I never used PTO implements on one, but the implement (notoriously heavy bladed brush cutters) could continue to drive the machine forward or backward after pushing in the clutch.
I first heard of over running PTO clutches in a 4H ag safety class when I was very young. It was quite a shocking class for the age group!
   / New Member Looking At First Tractor - Ford (9N/8N) #39
My first tractor was a 1951 8n, which I bought in 1990 from the widow of the original owner. I used it as my primary tractor for a few years. Its biggest handicap is the lack of live hydraulics. Lacking live pto was easily addressed with the addition of an overrunning coupler.
I still have that tractor and I use it for the tasks it does very well, such as plowing with it's original 2 x 12". The tractor was literally designed around that implement, and to this day, no modern tractor does a significantly better job on it.
I also use it on my 2-row 3-point corn planter, which is ideal for smaller, garden sized plantings of sweetcorn. The low operator platform, easy to get on and off from either side, and quiet, smooth gas engine, make it very convenient and comfortable for planting corn.
I maintain those "organic" corn plantings with a 2-row cultivator, which is much faster and more comfortable than the offset "cultivision" farmall that I struggled with for that task, for a few years.
I don't think you would be making a mistake getting an 8n as your first tractor. They have the best parts availability of any make or model, and are close to the top, when it comes to durability.
They have their weaknesses for sure, and might be one of the worst tractors to put a front loader on. If you use them for tasks where they excel, they will have no trouble providing multiple lifetimes of good work.
   / New Member Looking At First Tractor - Ford (9N/8N) #40
The n series tractor has one goal and purpose and that is to kill you.
If it can't kill you it wants to tear your limbs off.
If it can't do that it wants to turn over on you and it's not easy to jump off how the running boards and pedals are set up.
If it can't do that it will try to ram fences, buildings, cars, and other people's property as it's out of control.
It constantly tries to do these things while you're trying to get work done.
Get a newer tractor. Leave the Ns in the museum where they belong.
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
1968 Oliver Model 1950 2WD Tractor (A56438)
1968 Oliver Model...
