2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,632
How steep are the hills you plan to operate on? Not sure what slope is too much, but there is a point where a tractor might not be the best option.
Indeed it is a large endeavor but I am optimisticYou are starting in on a big project. A home site involves a lot of digging, shooting ranges do too. And a half mile of gravel driveway is a huge project by itself. 50 acres is a lot of land. All these would go better if you start with a larger tractor.
If you are able to handle normal machine maintenance and repairs, consider a used full size yellow backhoe/front end loader like you see on construction sites. Popular models areCase 580, JD310, or older Fords. Those older construction machines are incredibly durable & parts are always available. There are more knowledgeable mechanics in the construction world than there are for compact tractors.
You can probably get a decent older construction machine for the same price as the new 45 hp LS you are looking at. $30K will buy a nice one. It will do far more, last longer, and might even come with a decent size cab.
If you want to buy new, then any of the compact tractors will do about the same job. Buy from a dealer that you trust, one who has a good-looking service shop. The best dealers will have a mobile service rig so that the mechanic can come to you. Get as much HP and as many features as you can afford. You want hydraulic remotes and a quick change FEL bucket with a reinforced cutting edge..minimum.
Comparing tractors by frame weight is always a good idea, so look for tractors that weigh the most before loading the tires. If you have rocks, look for tires with upgraded sidewalls & the most ply ratings. Industrial tires do better on slopes than Ag lug type tires simply because they are wider. Don't base your decision on manufacturer's claims, particularly claims comparing loader or engine performance. Loaders and engines work about the same throughout the industry - although they are often measured differently.
Good luck,
rScotty
We built our place. Lots of TBNers have. It may be worth a search for a used yellow full size machine. Consider talking to a maintenance shop foreman directly. There are probably more nearby than you know. Small towns, schools districts, churches, local utilities, and shopping centers - any place with their own maintenance shop are all better bets for used equipmant than dealers or construction companies.Indeed it is a large endeavor but I am optimistic. Those things certainly have some oomph behind them, pretty powerful machines. I looked but for something that wasn't clapped out it was quite a bit more cash than I am wanting to pay, and their weight is pretty substantial. I am cash paying for everything and it is piling up quickly, as would be expected. Great advice on the dealership portion, I would guess that would be pretty helpful.
