New kubota tractor advice
/ New kubota tractor advice #61
You could use a stump bucket for digging up rocks & stumps which they are designed for. Grapple lids are also available for the stump bucket. They are sold by several manufacturers, Quick Attached, Everything Attachments, etc.
/ New kubota tractor advice #62
Thank you. My debate now is if I do get one 4,000+ would I be stupid to take a very expensive grapple and get rocks out? I don't want it to bend. Pallet forks I assume are cheaper and it would be their only purpose, not that I'd wanna bend them but it wouldn't much matter other than resell when I was done with them.
If it is wrong to take a good grapple to do what I'm wanting to do one alternative is subsoiler. Could I possibly use a subsoiler to pop them out a bit loose without tearing up my back end hydraulics? Bucket space I guess is an option but I feel grapple would be superior to it. Speaking something MX or bigger. If all this is bad ideas would the TLB series in kubota be a bad deal with the backhoe? Expensive for me but it is what it is I'd just wait until I could.
You have to look at the grapple/rock thing situationaly. My grapple has pretty stout composition. I wouldn't worry about rocks if all I'm doing is using the forces the way it's designed to be used, i.e. close the grapple on the rock. I'd worry more if I was trying to put sideways forces on the tines, for example if I was (and I wouldn't) trying to move trees with the tree between the tines.
That said, my particular grapple isn't the best at digging out rocks below the surface, the pallet forks are just better at getting in the dirt and prying the rock loose. That has limits too though.
A subsoiler will probably work okay for loosening small and shallow rocks, but isn't going to move bigger rocks like pallet forks might.
TL;DR: grapple is great for ... grabbing/grappling, and only on the horizontal plane. It isn't really a digger. Neither are pallet forks, but as an ad-hoc "use what you have" solution they're okay in a pinch.
/ New kubota tractor advice #63
Your better off just getting the l47 or older l45 tlb get the 3rd function and backhoe aux output get the 3 point arms you will have a tractor that will out work any ag tractor. And size isnt a huge tractor little bigger then most 35 hp ag tractors. I love my l45 tlb it's truly ment for working
/ New kubota tractor advice #64
Before shelling out tons of money for a new, heavier unit - consider how much it would cost to get a guy with proper machinery to clean up your trouble areas. Farming that job out to a guy with a mini-excavator (or renting one) to dig up your problem rocks, stumps, or whatever might be a cheaper option than buying a whole new unit that only MIGHT be able to do what’s needed. Your existing tractor might be sufficient to maintain those areas afterwards when properly kitted out with new tires, ballast, and/or chains.
/ New kubota tractor advice #65
I agree with the dozer or excavator suggestion . I have a B series and a m 5700 kubota and the M would have a hard time doing what you need done . I have a disc and they are not some magic bullet on the type of ground you are talking about . They will ride up over rocks and roots if there is any size to them . A disc really shines on plowed ground . I have a heavy duty spring tooth harrow and it will pull up medium size rocks with no problem on plowed ground , if on sod ground it will just pull up clumps of sod . Good luck with your project
/ New kubota tractor advice #66
If you are considering a disc w/ angled coulters along with extra weight in place, as you already know it seems, 26 hp may not be enough, not to mention the incorrect tires for traction purposes. There is a Till-Ease Model 543 Chisel Plow / Field Cultivator on the market that is built-like-a-tank but also small enough to access hard to reach areas / food plots. You may not need to trade-in for a new tractor but different tires may still be a necessity. The 5 coulters on the 543 are in-line (not angled) to slice the soil & tree roots (depending on diameter) before the five chisel plow / cultivator shovels turn the soil directly behind them. Two styles of cultivator shanks are included - standard chisel point & 9" sweeps. The manufacturer realizes the Model 543 will face virgin soil conditions often. Wisely - they have made the shanks easily removable into any configuration depending on type of soil or tractor horsepower. Even though the 543 has two plates for extra weight, it normally is not needed because the angle of cultivator shanks pulls itself into whatever depth is desired.
/ New kubota tractor advice #67
I see lots of post encouraging a larger tractor. While I have no problems with a larger tractor, will it serve your needs or cause you to not be able to do the work you need/want to do?
Even going to an L3901 from a B2601, I believe you will find a significant size difference. This size difference may mean you will not be able to get the L tractor to where you want to go (remember a longer tractor takes more clear area to make a simple turn, tight spots are not your friend, while a taller and wider machine present their own issues).
As others have stated you may try chains, you also probably need more ballast if rear wheels are coming up off ground—there is no traction when ground contact is lost. Another possible solution is getting R1’s for your B2601. It probably means new rims and tires all the way around, but much less than a new tractor.
One last big concern is safety! When you lose ground contact, you have lost stability. At this point you have increased the risk of equipment damage and personal bodily injury.
/ New kubota tractor advice #68
I wouldn't be disappointed with that machine. It's good at doing what it's supposed to do.
Making these efforts (and failing) helps you to understand the magnitude of what you're trying to accomplish.
I have a M7040 with power at all 4 wheels, and I wouldn't expect it to be able to yank that stump out, unless the stump is decayed.
Years ago I attempted to pull a fresh stump about that size with 6200 lbs. Ford F-250 4x4 (and failed). You're asking a lot of that little machine.
/ New kubota tractor advice #69
I have a B2650, only a few lbs heavier than yours as they come from the factory. But I have my tires filled with rimguard, I keep a 300 lb box blade on the rear and I have 480 lbs of steel plates hanging on that box blade.
By chance are your tires not loaded? I have around 700 lbs of fluid in my (larger than you have) tires, plus almost 800 lbs on the 3 point. My rears pretty much can not lift. Another thing I did was adjusted my loader hydraulic pressure up... more than the WSM says is allowed. That makes a huge change in loader performance.
You might be able to add weight to what you have and get where you need to be as far as traction?
Sorry to say, you have a recipe for disaster there. Adding a LOT of weight to a too small tractor will eventually break something. Been there, done that. Same for overpowering your hydraulics. At best, the hydraulic pump will have a shortened life, at worst, you're gonna bend something.
A tractor properly sized for the job will always work better, and last longer, than overworking a smaller tractor.
/ New kubota tractor advice #70
If you're wanting to dig rocks with a grapple, get the right type of grapple, and a large enough tractor. I have a 4,400 lb dry weight tractor (with loaded tires and loader, pushing 6,500 lbs) for 5 acres.
If you want to dig rocks, don't get a wide clamshell grapple. You will catch edges on other rocks, making digging rocks almost impossible. Instead, get a frost bite (or Igland/Sundown Gr-20) style grapple. They are cheaper too (~$1,500). It is much easier to get under rocks and pop them out. You can do it with forks, but then you are changing implements to pick them up and move them.
The earlier advice to first break the soil up with a subsoiler first is sound advice as well. I learned that too late.
Here are two piles of rocks I dug out last summer using a Sundown GR-20 grapple to put in a parking pad that was about 30 ft × 40 ft. I have extremely rocky ground.
/ New kubota tractor advice #71
The TLB backhoe come off so I can use other implements or is it permanently attached? Digging stumps and rocks with success was that with the MX backhoe?
Mine was an L4610, close to being the same tractor as the original MX4700/MX5000's from early 2000's. Had a 9 ft detachable subframe BH that weighed 2k lbs and spec'd comparable to an L47 BH. Tractor + FEL + BH were about 7,500 lb. I think the BH for today's MX's would be similar, plus more modern features.
/ New kubota tractor advice #72
I don't believe has mentioned renting a compact excavator to do the hard work. To minimize the rental time, I would drop the trees first, limb them and cut the trunks into 10 foot lengths. Then walk the excavator through the area to be cleared, windrowing the brush to one side as you go. A small excavator with a thumb will make short work of the stumps you have in your photograph as well as the rocks. Raking the soil with the teeth on the bucket will get many of the roots and rocks. You can cut a swath, limited only by the reach of the excavator arm, with each pass. You can shake the dirt off the stumps before windrowing. That makes it easier to burn if you are allowed to. Just a method that I have used that goes surprisingly fast.
/ New kubota tractor advice #73
For the stumps, have you considered a stump grinder instead of yanking the stump from the ground?
/ New kubota tractor advice #74
I think you need to go to industrial line of tractors until at least you rid of those issues. Maybe all the time.
I'm now looking at bobcat CT4045 with Ag tires. 3,745 pounds which would be more once I add fluid to tires and a box blade. 44.9HP. You guys think this would be reasonable for my property? These things wouldn't be one time, I will also come up with new ideas to do.
I really like that frostbite grapple. I could concentrate on just 2 tines going into ground then a bunch more that wouldn't be needed. Issues I could see is if the rock was too small to fit between both while popping it out. If I used one side could I warp my loader arms or warp the frost bite grapple, taking into consideration I take my time and not ramming it? Assuming it's still great for moving brush piles.
/ New kubota tractor advice #76
Most everything you're describing is due to weight and traction issues and I think some unrealistic expectations of what a tractor can do. A slightly bigger tractor won't necessarily solve those problems by itself. I have owned B and L models, and if anything the L is lighter in the rear (proportionally) than the B was. The L needs more work/prep/care to keep the rear on the ground. I am more conscious about ballast on the L than the B. An advantage of the L is ground clearance.
Ground engaging work needs to be happing from the rear of the tractor, in a pulling motion. Front end loader is not appropriate for ripping out rocks and stumps, though some people will abuse their tractor to attempt that work. Some of those chores are for backhoes, and some need dedicated backhoes.
I don't plan on ripping out stumps. Only the rocks. I'd use the bigger tractor and logging chain to hopefully pull some small trees to remove their root ball.
/ New kubota tractor advice #78
The frostbite style grapples have an easily removed plate that spans the two lower tines (see picture). That allows you to pinch, and pick up rocks the size of softballs (depending on operator skill ). In the picture, the top clamshell is contacting the lower plate in it's current orientation. A camera mounted to the grapple makes it much easier to see what you are doing.
Or it can be removed to make the tines dig in easier. I leave my plate on pretty much all of the time as I've had no problem getting under rocks and popping them out with it on, and it makes it easy to get the smaller ones out.
I have a similar sized tractor (LS XR4145) with a loader with max lift capacity of 2,700 lbs at full height. With the grapple I've never been worried about twisting the loader. The tines are spaced close enough it's almost a non-issue (I imagine if you tried to pick up a massive rock so it's cantilevered out on one end, you could run into problems).
/ New kubota tractor advice #79
What was the price on your tractor? I think bobcat is offering free loaders. This tractor would be roughly the weight of an MX I believe but a less hp.
I paid 14,000 for it brand new on close out when they quit making them the first time around. I feel that was a steal of a price.
/ New kubota tractor advice #80
Sounds like a good plan to me. Could always add a backhoe later if the grapple doesn’t work out.
Chemical Containers Tank (A57148)
Chemical...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
USC Series 2000 Conveyor (A61306)
USC Series 2000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 1025R (A53317)
John Deere 1025R...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
