New Gas Range
/ New Gas Range #22
Originally Posted by Wakey View Post
Deano,
This is it.. Amazon.com: Norpro Heat Diffuser: Heat Defuser: Kitchen & Dining
Cool beans, wasn't aware of this or the LOW adjustment on the valves, thanks Wakey and Gem99ultra
I have a few of those style, some times you need more than one.
I DO like the ones by Lodge better though...
SR
/ New Gas Range #23
I had the exact same stove. Loved it!
On another note, gas appliances tend to be built with higher btus now - it痴 a marketing thing.
Also how old it the regulator on your propane tank/line. They don稚 last forever and should be replaced every 10 years.
Enjoy!
/ New Gas Range
Hey Marchana, I don't believe my tank regulator would be a problem. It is not even a year old. We bought a buried tank and had it put in last spring. I expect the adjustment screws will solve the problem, but I am not there right now... I'll have to wait a couple of weeks!
/ New Gas Range #25
/ New Gas Range #26
The electronic igniter may not work, but everything will operate when started with a match.
The reason I asked was a Lowes sales rep said the new ones had something like valve that had to have electricity to allow gas to flow.
/ New Gas Range #27
Mine works just fine by lighting it with a match...
Not that, that matters much, as you can always cook on a BBQ or in my case, I also have a wood fired cook stove in my garage that's on wheels. Just push it outside and fire it up with scrap off my BSM.
SR
/ New Gas Range #28
We had a gas stove that you could light the burners with a match if the power was out, but you could not light the oven. There was an electronic igniter block that had to heat up before the gas valve would open. No way to light it manually.
/ New Gas Range #29
I see you have the high BTU burner as well, did you get the wok cradle? 20171224_102651.jpg
Man, at least twice a week haha Chinese Take Out Recipes - The Woks of Life
/ New Gas Range
No wok cradle, Wakey. We use a large cast iron skillet for most things. It was a 都econd from the lodge store and was super cheap with a tight fitting lid. You cannot tell it is a second.
/ New Gas Range #32
Their recipes are the best I've found, yet.
So far i've only attempted the "take out" section and they have a huge glossary and many suggested kitchen tools.
Stir fry wrecks the stove but it is worth it.
Thanks for posting the link to "Woks of Life". Santa brought me a new Lodge cast iron wok to use on our gas cooktop.
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 INTERNATIONAL...
PT 1000 Gal Tank (A64912)
PT 1000 Gal Tank...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
PORTA POTTY (A68842)
Billy Goat DL2500S Debris Vacuum (A64912)
Billy Goat DL2500S...
Metaltech Climb and Go (A64553)
Metaltech Climb...
