New AGCO 5670
/ New AGCO 5670 #1
nickwi
1959 Allis Chalmers D14
Just picked up a 2000 hour AGCO 5670 4x4. Excited to get it home. Grew up farming with Allis Chalmers D14, D14, D17, 185. I know it's actually built by SAME.
Wondering if you have any advice of things to check over closely when I get it home. Planned to take off engine shroud to clean cooling fins and check the fan drive belt, change fluids etc. anything else?
Thanks in advance, I'm sure there will be more 😊
/ New AGCO 5670
/ New AGCO 5670
Had the chance to do some bush hogging. Great power and economy. Engine oil and filter changed. Hyd filters ordered. Fan belt in good condition. Small weep around the PTO, probably needs a new seal.
/ New AGCO 5670
4 brand new tires was really pleased with the tractor. Now I just hope I can find parts when needed!
/ New AGCO 5670 #6
Any used tractor I have purchased I strip all the sheet metal off and do a through inspection and cleaning and change all fluid and filters. Glad your purchase is working out good.
Making sure no leaks after repairs and cleaning.
Another purchase
/ New AGCO 5670 #7
I have four AGCO Allis tractors, they have nothing to do with Allis Chalmers.
They ARE very good tractors, good low-end torque and good fuel economy.
I buy my parts/filters from my AGCO dealer, but oil filters are available at NAPA.
SR
/ New AGCO 5670
Thanks for the input. I want to start getting lights working. Read a few times that the Same aren't known for great wiring. Before I tear the whole console out, could you tell me where the fuse panel is located? Looking from under the dash, all I see is fuel tank. Thanks!
/ New AGCO 5670 #9
SR
I have 3 AGCO tractors and I like them a LOT. Excellent AG dealer support and lots of great features.
Never overlook AGCO or Massey tractors.
/ New AGCO 5670
I found it! On the firewall right above the engine. Looks like European style fuses.
/ New AGCO 5670
Sure enough, all fuses looked original. Two blown. Replaced bulbs with LED, much brighter! Added a couple of work lights. Did some fall chisel plow work, seven shanks with disks on front. Pulled it like a champ and good on fuel👍
/ New AGCO 5670 #12
Looks like you don’t have to worry about changing the antifreeze 😁
/ New AGCO 5670
Exactly! It's very efficient and low maintenance. Put a better seat on too.
(1) 24X9.50-12 TIRE W/ 5 LUG RIM (A64280)
(1) 24X9.50-12...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2000 Dodge Ram 1500 Cargo Van (A61573)
2000 Dodge Ram...
