neutral hydrostatic roll
/ neutral hydrostatic roll #1
vaj
Lagrange, NY
JD 310d, JD 4110
To prevent diesel fumes from entering my garage, I started pushing/rolling my jd 4110 hydro right outside beforre starting it up. Is it possible to do any damage internally or is this a no worry issue?
Thank you,
Tim
/ neutral hydrostatic roll #2
As long as the gear selector is in NUETRAL, there is no problem. I sometimes do the same thing.
/ neutral hydrostatic roll #3
I take it your putting the range selector in neutral. That's the only way you'd be able to push it by hand. It's not going to hurt a thing. Not on the tractor anyway ;)
The operators manual says you can tow the tractor this way too. At least it does in mine.
/ neutral hydrostatic roll #4
Thank you,
Tim
Tim:
Welcome to TBN :D! I hope your driveway is level. You do not want to get that tractor away from you. I ran over my foot trying to stop my Honda CRX Si once :eek:; no damage to me-very light car :p. I did drag it to a stop rodeo style :eek:. I do not see a problem if your HST in neutral. Jay
Thank you all, yes it is in neutral.
I tell you when I was young, my Father had a diesel Audi and Mom a diesel Volvo, - that garage was black.
Mine will not be that way.
/ neutral hydrostatic roll #6
Don't see that it could damage anything in neutral.
You must park yours with nothing on it. I park mine with the FEL and whatever's on the 3 ph in down position. Would have a hard time pushing it out of the garage even in neutral.
My 4010 starts with white or blue smoke, no black.
Ralph
/ neutral hydrostatic roll #7
heck I can't pull my 90hp 4x4 tractor with the FEL and 3PH in the up position with my Dodge 3/4ton diesel 4x2 unless it is on pavement. On flat ground, all I do is spin my tires.... It takes 4x4 Low on th Chevy to get it moving if it needs a pull start and that is one uncomfortable ride for the poor guy in the truck.When you let the clutch out on the tractor, it feels like you are hitting a brick wall in the truck.
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
1043 (A60430)
1043 (A60430)
2010 CHEVROLET SILVERADO 2500HD (A65643)
2010 CHEVROLET...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
