Need radiator help
/ Need radiator help #1
Flemdog377
Pueblo West, Colorado
Yanmar 155D
Had to buy a radiator for my YM155d, the new ones mounts are spaced too far apart so I made some brackets to fix the spacing. Once I thought I had my mounting issue addressed i find out my stock fan shroud will not fit on the new radiator and it rubs the fan. I know there was a design change and I was hoping to get directed to a maybe proper fitting radiator or have recommendations made on what to do?
Thanks in advance
/ Need radiator help #2
Thanks in advance
Is the radiator too deep in depth to cause the cooling fan to rub the fan shroud?
Or is the radiator too wide causing the shroud to flex inwards and the fan rubs?
There are two different ways at looking at this from your description.
The shroud won't fit on to the radiator, and if I adjust to get it around the fan the shroud seems to set too low
/ Need radiator help #4
Are you capable of fabricating a new shroud then?
/ Need radiator help #7
I was going to take a grinder to it and adjust if I couldn't get any other ideas
With a 40yo tractor and newer replacement radiators, there isn't much to offer.
Remember to measure twice and then thrice before making any cuts.
Think it through before starting the work.
40yo plastic doesn't behave as nice as new plastic.
It might be a little on the brittle size.
Use caution.
/ Need radiator help #8
Try mounting a larger fan. The mounting bolts will stay the same. Except on the YM240. Which are 2" to the Fan Mount. The 155D Fan # CF-4474. Radiator/cap # RA-4060.
Models 135,155,165,1100,1300 uses it. Look for those models for the Shroud. I have no # listing for it.
Unused 2023 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2023 Land...
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2017 Ford Escape SUV (A66738)
2017 Ford Escape...
CAT IT28B Cab (A68134)
PORTA POTTY (A68842)
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
