My New J2023 Initial Review
   / My New J2023 Initial Review
It will be in the loader manual ... it will specify how much ballast is needed
Says "Add wheel ballast and/or rear weight to counterbalance tractor/loader for stability at maximum loader capacity."
   / My New J2023 Initial Review #12
Check the main specifications page in the loader manual... the page that gives dimensions, lift specs, etc
Nothing there about how much fluid to use. That's only specs for the loader parts.
   / My New J2023 Initial Review #14
Hmmmm ... in the specs page for my loader manual is where the recommended ballast amount was listed (when I had the R4047). Not fluid amount ... ballast amount. They likely won't list a tire fill amount.
Here is the specs page.
   / My New J2023 Initial Review #16
Looks like they don't list it ... sorry, that was my best shot. Have you called & asked the dealer? They may have it
   / My New J2023 Initial Review #17
Go to the Rim Guard site, they have a chart that could help you.
   / My New J2023 Initial Review #19
Am I correct that loaded tires do not act as a "counter balance" to the FEL? -- Loaded tires do not relieve the weight stress on the front axle when using the loader? -- Loaded tires just improve traction and stability?
No, they DO act as counterbalance.
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
