My New J2023 Initial Review
/ My New J2023 Initial Review #1
Olympus
Cape Girardeau, MO
LS R3039
So I just took possession of my new J2023 today. First thing, I have to say thanks to Magee Equipment in Poplar Bluff. I was only able to get to the dealer today (Sunday) and the dealership is normally closed. However, the owner gave me his personal cell phone number and I texted him and he said he would come down to the shop on his day off so that I could pay and pick up my new tractor. I thought that was a pretty stand-up thing to do. After paying for my tractor, the owner gave me some cash back and told me use it to fill the tractor up with fuel since it just came in two days before. He said he always sends his tractors out with a full tank of fuel. So I loaded it up and headed home (I had to stop by some friends' and familys' houses on the way home to show off).
The first thing I notice about these tractors is the fit and finish. They are very nicely made! Nothing cheap or cheesy looking for feeling on the tractor. It is really a SHARP looking little tractor! It looks better in person than the photos. The tractor fires up quickly and runs smooth and quiet. The loader operates nicely, even at idle speed. The platform is noticeably more roomy compared to my previous John Deere 750. I'm 6'1" and I can easily get up and down from the platform. The seat is adjustable which is nice. I was able to rack the seat back so that my right foot was in the perfect spot for the DUAL hydro pedals. None of this rocker/treadle pedal stuff on the J2023 model. MUCH more comfortable and natural feeling to me. The controls are laid out nicely. The left fender has 2wd/4wd selector along with the Hi/Lo range selector. The right fender has the PTO knob, 3pt lever, and PTO selector for rear, mid/rear, and mid only PTO engagements.
My driveway needed immediate attention, so I hooked up my grader blade and went to work. It took me a while to get used to the 3pt lever since I was used to position control on my previous tractor. I also had to do some adjustment on how fast the 3pt dropped. But after a few passes, it felt like second nature. One thing I did notice is that this tractor seems to pull more easily than my John Deere 750. My LS could pull a blade full of gravel at 1500 rpms without any problems, while my 750 needed to run about 2000 rpms.
Then I did some very minor bucket work pushing some piles of dead limbs and stuff together to be burned. This is where I found the only thing I need to change about the tractor. I'll be filling my rear tires with fluid soon. I lost traction pretty easily when trying to push the brush piles together. The ground was soft and I think that had a lot to do with it, but my tires glazed over pretty quickly. I need some more weight to help give me some tractor, even in 4wd.
But needless to say, I'm very happy with my little tractor. I put 2 hours on it this afternoon playing and I'm looking forward to many more! And here are some "un-trailering" photos for your enjoyment. And here's a link to short "walk-around" video I posted on YouTube: https://www.youtube.com/watch?v=VRpGDcxu-MU
/ My New J2023 Initial Review #3
Thats a nice machine! I especially like where all the levers and buttons are. I'm so glade my 4041h has dual pedals and not that rocker type! Congrats!
/ My New J2023 Initial Review #5
She's a beauty! :thumbsup: (Love the dog, too :D).
/ My New J2023 Initial Review #6
Will you be using some form of 3 point ballast when using the loader?
Nice looking tractor. Great value.
I won't use a ballast box because I'll always have some type of implement attached, but I am going to fill the rear tires.
/ My New J2023 Initial Review #8
Not to get in to your business too much, but some tractor owner's manuals make clear the difference between loaded rear tires and a 3 point ballast system SPECIFIC to use of the loader.
If I have it right, loaded rear tires help keep the rear end on the ground. A 3 point ballast will keep the rear tires on the ground AND off-set the load on the front axle. Over the life of the tractor that offset of load concept can really save wear and tear on the tractor's front axle components.
Your owner's manual may suggest a 3 point ballast weight range to work within that will match your loader's capacity.
Please keep in mind I'm no tractor genius. Take my thought for what it is worth. (Other more knowledgeable folks can speak to this "off-set" concept I'm mentioning).
Again, you've got a fine tractor there. Good luck.
I just got done reading the manual. Nothing mentioned about filling the tires or using ballast boxes.
/ My New J2023 Initial Review #10
It will be in the loader manual ... it will specify how much ballast is needed
Says "Add wheel ballast and/or rear weight to counterbalance tractor/loader for stability at maximum loader capacity."
/ My New J2023 Initial Review #12
Check the main specifications page in the loader manual... the page that gives dimensions, lift specs, etc
Nothing there about how much fluid to use. That's only specs for the loader parts.
/ My New J2023 Initial Review #14
Hmmmm ... in the specs page for my loader manual is where the recommended ballast amount was listed (when I had the R4047). Not fluid amount ... ballast amount. They likely won't list a tire fill amount.
Here is the specs page.
/ My New J2023 Initial Review #16
Looks like they don't list it ... sorry, that was my best shot. Have you called & asked the dealer? They may have it
/ My New J2023 Initial Review #17
Go to the Rim Guard site, they have a chart that could help you.
/ My New J2023 Initial Review #19
Am I correct that loaded tires do not act as a "counter balance" to the FEL? -- Loaded tires do not relieve the weight stress on the front axle when using the loader? -- Loaded tires just improve traction and stability?
No, they DO act as counterbalance.
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
2024 JCB 270T Compact Track Loader Skid Steer (A66734)
2024 JCB 270T...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
