My new Ford 4000
/ My new Ford 4000 #41
**** good feeling, that first go ain't it? Thanks for the video, almost like being there. ;)
/ My new Ford 4000
Yeah, it really was. Luckily I am a teacher, and have been off all summer. So I have been able to do a lot of internet research, and reading in general. It has been parked in my garage, which means I have logged some serious hours on that *******. We took a risk, although not too much since it was so cheap, but we right now we got a running and rolling tractor tractor, b-hog, and blade for some manual labor. We are about $250 into counting, manuals, solvents, rebuild kit, solenoid, oil, filter, plugs, etc etc etc. Figure we got another $100 or so in fluids, and an air cleaner in the future. Will be needing tires eventually, maybe a rear rim.
Real question is this a long term machine for us, or something to sell to get us into a machine that is more "maintainable". The SOS tranny, and availability of parts has me a little worried. Guess we shall see. I have learned a lot in the last 6 weeks.
/ My new Ford 4000
My temp gauge and capillary tube appear to be shot. Anything special I need to know about swapping it out? Looks like a simple remove the tube engine and gauge from dash and insert new one at both ends?
EDIT: Scratch that....it works
/ My new Ford 4000 #44
Nice rowcrop!
/ My new Ford 4000 #45
Someday something could go South and prove not worth investing further. At that point you might part it out (or sell whole for that) and make most of your bucks back, considering total $$ so far. :)
A suggestion: 'lash' the valves (per manual) if you haven't. You may get the carb sorted out sooner than it's running smoothly and not be so sure what's up. (low power, slightly rough running w or w/o load)
Next would be a compression/leak-down test w/ all s-plugs out when cranking/reading. You might have done this before on something and be familiar. If not, a few more bucks at HFT for a 'close enuf' gauge, w/adapters if needed.
(It could smooth out some if the rings are stuck (comp test will show) and loosen after more warmups/hours.)
Y'know a guy wouldn't find a quad with food plot tools for such low $$ ... or likely want to park one on site. ;)
IMO, 'specialization' is for tractors. :cool2:
Nice 'package'! :thumbsup:
/ My new Ford 4000
Old Grind,
It is even better than the original price. We got the package in exchange for some sweat equity, no $$$ out of pocket. My buddy is doing some electric and carpentry work and I am providing the initial $$ to get it up and going. I havent spend a penny outside of the parts/fluids/supplies to get it up and running.
The video makes it sound a little worse that it really is. I think it is "loosening" up a bit. Had it running in the garage today, sounded smoother. Right now the struggle is the low RPM idle. Cant get it to idle below about 900 RPM, and I need a little choke to accomplish that. Assuming the TACH is correct. The hour meter works, reads 2786. my gut tells me it is original. Getting out and driving freed up the Park safety switch. Previously I had bypassed it, but today it occurred to me that we might have freed something up. So I removed my jumper wire, and hooked the Park switch wire back up and it fired off.
I realized that I didn't set the float level prior to reassembling and attaching the carb. :banghead: Wonder how much is affecting things.
Looking forward
Need Air cleaner
Battery
Swap Tranny and Diff fluid,
Not sure what "lash the valves" means.
Thanks for the advice and encouragement. Amazing how these things can sit for years, years, and years and spring back into action so quickly.
/ My new Ford 4000 #47
If you have an I&T manual (you said earlier?) 'lash' would be under valve adjustment or similar for the walk thru' and spec'd with your engine's other details in the front pages. Valve cover comes off ... (btw, look for foreign matter, sludge in/under it) ... and you'd want any ol' feeler gauge set and a new VC gasket on hand.
btw: you may not be confident at first when positioning the crankshaft (twice during, just turning by hand with s-plugs out) but the instructions are in pretty plain English (if I'm not always :rolleyes:) so ... IMO 2-3 of 5 on elbow grease or difficulty even if not much experience under vehicle hoods. (compression test ~ a 1, btw) :)
Possible causes for 'lean'/weak idle besides incorrect float level are carb or manifold gasket leak, plugged pilot jet, throttle shaft leak, vacuum leak to distributor advance biz, even stuck advance weights that don't ******. btw, at 900 rpm, needing the choke does mean something is 'up with that'. :laughing:
General bits from me, and not make/model-specific. As always, expect much good Ford help from TBN'ers who wrench & ride 4xxx's vs uh ... just envy someone else's. :eek:
/ My new Ford 4000
T.O.G.
I'll put that one a little further down the line on my To-Do's. I will double check manifold and carb bolts. Thanks
/ My new Ford 4000 #49
Sure. And sorry if my 'important' sounded like 'urgent' too. ('not') :eek:
Oh, and "that's all I got" for now, but I'll be 'following'. :drink:
/ My new Ford 4000 #50
, vacuum leak to distributor advance biz, . :eek:
You will look a looooong time trying to find a vac leak on that machines distributor advance mechanism...
/ My new Ford 4000 #51
Yeah, I was a bit broad with the list there ... :eek:
... General bits from me, and not make/model-specific. ...
Didn't mean/need to step up from 'lurking blue', but have done my share of troublshooting and 'waking the dead' (both a fascination) and I kinda blurted.
Looked in while pondering a ~50 hp Ford (basic gear vs SS or shuttle, btw)... hoping to gain familiarity by following other's 'work' on such. (I'll be quiet ... :))
/ My new Ford 4000 #52
I enjoy these discussions as well. I always learn something. If I can just remember where I store it in the old brain. :)
/ My new Ford 4000 #53
Dang envious that your 4000 is as close as the other side of the wall in your garage, my 641 is an hour away and I haven't been able to get up to it in a few weeks. It's killing me! Lol
/ My new Ford 4000
Yeah, that is pretty handy. Once we get it ready to go it will leave at my little slice of heaven about 75 min away.
/ My new Ford 4000
What these two small holes in the my carb? I am suspicious of these two as the source of my idling problem. The rear one with the brass fitting, seems to have a 2nd smaller orifice inside, and when I shove a needle into it as far as it will go it come out dirty, think there is some shellac from old gas in there. Where is the outlet for these? Everything else I am able to both ends of the passages, but these two I cannot.
The main nozzle in the back, it not held on with a nut. It appears to be a single piece with the jet on the underside, I cannot get that jet out. Might try to heat it, but the top of the jet is getting deformed. Idle jet is being difficulty as well.
Thanks in advance
/ My new Ford 4000 #56
Here is a photo of my 871 inching pedal. Yours should be similar. Possibly someone replaced it with something else. Post a photo if you can.
Yes the PTO will spin when lever for driveline is disengaged. You are disengaging the trans to rear not the pto.
I never cared for ford's gas line routing through the manifold I run a steel line from the tank towards the front of the engine bend into come around over the alt/genny, sometimes will add rubber hose, and easy access shut off. If I remember correctly some of the earlier lines were 1/4 and some were 3/8 depending on the carb/manifold you have.
Kirk
Had a few cans of Silver left over, did ya? :) Nice looking..
/ My new Ford 4000
Thanks in advance
OK, after lots of reading I have determined that the top, smaller hole, is the air vent that leads to several bleeder holes in the nozzle. The lower, larger holes in the terminal end of the idle fuel passage, and after the gas passes through this it enters the idle jet and will then be mixed with air and out the 2 idle orifices. I cannot for the live of me determine where the origin of the idle fuel passage it, or how gas enters that passage?
This picture,v840.jpg clearly is just for reference and doesnt reflect the actual location, length, or orientations of the actual components. But for the life of me I cannot determine how the gas travels from the fuel bowl #1, into the idle fuel passage # 10. Since I never found it, my gut tells me it is at least partially blocked and the source of my tractor's idling woes.
/ My new Ford 4000 #58
The main circuit just isn't shown in the diagram. (fixed, so no 'adjustment' info)
Fuel is drawn (up) into the idle circuit by the high vacuum behind the throttle plate at idle. btw, the 'secondary orifice' is to smooth the transition coming off idle and reduce 'bog' as vacuum drops briefly then & w/o an accelerator pump, ... if one wonders. (lawn mower-simple)
That large tube may have a fixed orifice (out of sight), is likely pressed in, and IMO should be left as is (in place) for now lest putting it back in be much more trouble than removing it with no reason 'indicated'.
(off-idle running is ok, no? ... a KISS epiphany here?)
Gunk that fresh gas didn't yet flush from the idle circuit/jet is ... like, jumping up and down waving a red flag as the cause of lean running. IMO, one little thing to fix and one 'baby step' that may get you walking. jon
/ My new Ford 4000
Yeah,
Looks like the there is a orifice in the nozzle that allows gas to enter the idle circuit, and it is clogged. Without getting that tube out then I will struggle to get it cleared. My partner has a compressor, maybe we can get lucky and just blow it out.
/ My new Ford 4000 #60
The only thing that is silver on my gold demo is the caps that attach to the shifter and the rear PA rims
Kirk
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
HUSTLER RAPTOR SD ZERO TURN LAWNMOWER (A60430)
HUSTLER RAPTOR SD...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
(1) KENMORE REFRIGERATOR (1) FRIGIDAIRE STOVE (A60432)
(1) KENMORE...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
