My new Ford 4000
/ My new Ford 4000 #61
The only thing that is silver on my gold demo is the caps that attach to the shifter and the rear PA rims
Kirk
Huh.. On my screen, the first pic looks silver... might be time to adjust my monitor.
/ My new Ford 4000 #62
My Son has a demo gold tractor but it ain't that pretty. :)
/ My new Ford 4000
Gentlemen,
I am struggling to find what I need for the air cleaner assembly. I have the J Tube, but I keep seeing air cleaners that look like this wm_C5NE9600E.jpg. I cannot figure how this connects to the carb via the J tube. The hood has, the air funnel. Just not sure what the heck this is supposed to look like? I can find a pic of the air cleaner mounted on the tractor with the hood off?
Seems like the air should enter the air cleaner from the side based on the air funnel that is mounted on the inside of the hood, but everything I see looks like the air enters from the top, and I don't see how the J tube would connect. Can someone give me a hand with this?
EDIT: The parts # from this illustration give me nothing when I google them. View attachment Air cleaner2.pdf
Kurt
/ My new Ford 4000 #64
Here is the one you need. Look up for ford powermaster 801 tractor, it's the same, both for the 172 engine. There were two different 4000's, the early 4 cylinder model and the later 3 cylinder square nose model.
Kirk
/ My new Ford 4000
Kirk,
Thanks for the pic. I was able to track one down on eBay for like $35. Not the prettiest but should be serviceable. s-l1600-2.jpg. Even searching for the 801 air cleaner didn't yield many results.
Got the main jet/nozzle out of the carb last night. Pretty certain that was the problem with idling.
She is coming together. Change some more fluids, get the carb back together, get the air cleaner up to speed, legit 6V battery. We will be getting close.
What to do about the paint/rust? I don't wanna just half as spray paint it, but letting the existing rust just continue to get worse also seems silly. I am not going to do a fully restoration paint job to get it to factory new in appearance. Is there a happy medium where I don't look like somebody with a total piece of crap that just slapped on paint hoping to make it it sell for more? I have no plans to sell at the moment, I want it for work. But having it look nicer is also appealing.
/ My new Ford 4000 #66
I suggest using without new paint for a year. Then paint it to the standard the tractor has earned.
/ My new Ford 4000
Ok just want to make sure I am on track with fluid drain and refill locations.
1)Pic of the big round plug with the square lug shows the differential fluid fill, right under right butt cheek
2)Underneath looking towards the rear of the tractor shows the hydraulic drain plug, then further back the differential drain plug.
3)The other pic underneath looking forward shows the tranny drain plug and oil drain plug (oil is already swapped so no worries there)
4)Pic looking forward at the rear left of the differential is the diff fluid inspection hole
5) The pic is by my right heel looking under running board, the hydraulic fill hole?
Think I got all correct?
/ My new Ford 4000
OK, I found the hydraulic fill, big cap right under left side butt. Looks just like the diff fill cap, but tilted at an angle.
Trans fill hole is the same as the trans trans check plug
/ My new Ford 4000 #69
Trans fill is on top, check plug right side.
/ My new Ford 4000
I just filled through the inspection plug on the side. Right at 11.5 qts in before it dribbled out. Didn't see any fill hole on top of the S-O-S.
In related news, I solved the idling issue. My partner in crime on this tractor and his dad were able to get the main jet and nozzle out, got that cleaned up. Idle fuel passage is clear. Idles rather nicely now. Cleaning up the air cleaner I got off craigslist, just some tough up painting on the spots we sanded off the rust.
Also solved the PTO. We were able to stop the PTO with a 2x4 with the PTO cable control knob pushed in, but not able to stop it once it was pulled out. It was just fluid coupling.
/ My new Ford 4000
OK, new question. My All Purpose Ford Tractor manual indicates that the S-O-S differential requires 11 qts of fluid. I check the fluid at the inspection plug and it was full. I then drained the fluid, and it appeared to be about 2-ish gallons. I began refilling the fluid, and it started to weep out the inspection hole right at 8 qts.
That seemed odd. So I came inside and double checked my manual, yep 11 qts for the S-O-S, 8 for the 5 speed. I just assume that the plug was there for the 5 speed. So we added 3 more qts. But it my mind that seem a tad odd. Was doing some more checking and in my IT manual F-04 it says all S-O-S require 11 qts, except the RowCrop it requires just 8. What am I risking if I leave those 3 qts of fluid in the diff?
/ My new Ford 4000 #72
I just filled through the inspection plug on the side. Right at 11.5 qts in before it dribbled out. Didn't see any fill hole on top of the S-O-S..
Ahhh.. a 'save our souls' model. ;)
/ My new Ford 4000 #73
I don't have an SOS.
What do you risk with an over filled diff? leaky axle seals.
On row crops you also have drop boxes to fill on each side..
/ My new Ford 4000
Roger that. The excess fluid will be drained tonight. I haven't moved the tractor since I added the fluid.
/ My new Ford 4000
Soundguy,
You reference drop boxes, I have been searching the web and on the tractor, and have come to the conclusion that you were referring to the final drives on each side. I have tracked down that each take 1.5 qts of fluid, will the Universal Hydraulic/Transmission Fluid that I used in the differential be fine for these?
I assume in my pic that I've attached that the square plug is the inspection plug? Thanks for all the help.
Kurt
/ My new Ford 4000 #76
I don't see a pic attached. but the final drives have a drain and a fill.
sure... utf will work. i run 85-140 in mine...
/ My new Ford 4000 #78
fill thru the big sq plug till it starts to overfill and dribble out while you are filling.
the small square plug on the pan is the drain.
/ My new Ford 4000
Finishing up some paint, and minor details. Have to troubleshoot the generator light, hard to tell which terminal is which on this old genny. Need to get the as much oil out of the steering gear box and add some lube in there to keep the gears lubricated. But just about ready to roll.
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
Deere 310L (A53317)
Deere 310L (A53317)
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
