Moving Really Big Rocks
/ Moving Really Big Rocks #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Hey guys looking for some advice on how to move some really big rocks. I can easily push them with my dozer, problem is I can't get behind them, they are against a hill. I can't lift them with the loader and I can't move them with the hoe. I've had someone tell me drilling them and then setting bolts into the holes, with chain around the bolts and then hook the chain up to the dozer and drag them. I am not confident that a bolt would hold. Does anyone have any ideas on how to hook onto a rock and drag it. I can't get the chain around the rocks as they are against each other and digging under them I'd hit an electrical line. Any advice is greatly appreciated. I'll try to post a couple of pictures tonight.
As I type I guess I could try to break up the rocks, but the rocks I grow here are super hard.
Thank you in advance,
Joel
/ Moving Really Big Rocks #2
How about using an old car hood to skid them out? Or is the problem that you cannot dislodge them from their current site?
Yup, can not dislodge, will use your idea to slide once I do get them moving as they'll be sliding across my driveway. They are biggins. I am thinking about renting an airhammer and hammering them to death, or at least into a couple of pieces. Maybe easier than possibly tearing up the machinery or me.
/ Moving Really Big Rocks #4
I remember that here on TBN once I saw a thread about how to solve this problem. Wish I could remember more.... it involved drilling some holes in the rock.... with a masonry bit.... inserting a material that expands and if you put the holes in a line, then it is likely to crack the rock in half. I can't recall the name of the material... not an explosive.... I saw photos of this... seemed to work amazingly well... cheaper than renting a jack hammer....
I just did a TBN search... http://www.tractorbynet.com/forums/projects/86471-breaking-up-large-rock.html?highlight=crack+large+rock
discusses this problem... dexpan is the name of the material
Here is more about it Dexpan Non-Explosive Demolition Agent
here is the key post from that thread.
Less than $100 worth of Dexpan will take care of your problem. No need for a jackhammer, which probably wouldn't work anyway.
Dexpan is a controlled explosive. It works on the same principle as freezing water. it expands and cracks the rock in half or thirds or whatever you want. It does NOT explode. It works in a couple hours. No licenses or permits necessary. It is typically available at welding supply places.
Do a google search and you can find a local supplier in your area. Your existing equipment can then take out the smaller pieces.
/ Moving Really Big Rocks #5
Couple of ideas. We break granite up by drilling a series of holes, and inserting "pins, and feathers", or two wedges with a pin between them. It's amazing what you can break up with a series of these in a row. The other idea is if you can get your loader bucket under them at all, you can then loop a chain around the top of the rock, and curl the bucket back to tighten the chain. Perhaps that way you can drive backwards using the bucket itself as the "stone boat" or car hood replacement.
http://www.leevalley.com/garden/page.aspx?c=2&p=10335&cat=2,2180,41007&ap=
Thank you very much for the information, the expanding chemical sounds like the trick, I've got a nice big chuck hand power drill I can use to drill the rock and use the chemical. I used the chains and loader for the other large rocks, but can't get the loader under the last three I'm dealing with. The feathers sound like another great alternatives.
/ Moving Really Big Rocks #8
Joel,
I had the same problem last summer. What you need if Betonamit. You can get it at Taylor Rental in Concord. A 5 lb bag cost $60 and will handle most size jobs you have. Do not use a chuck drill. You will burn it out drilling into rock. You need a hammer drill, specifically a 1 1/2" drill bit. You can rent these also. The hammer drill will make life so much easier for you.
You drill 3 - 4 holes, mix the betonamit and pour in the holes. Cover the rock with a tarp and leave over night. In the morning the rock will be split in half or however you set your series of drilled holes. A friend used this when making his water fall, & I had to use it when I decided to dig up this "little rock" in the lawn. It ended up being 3 1/2 feet wide by 7 feet tall stading on end. I couldn't budge it with the backhoe. After splitting it I pulled out the top half and burried the bottom half. If I can dig out the pictures of it, I'll post them for you.
/ Moving Really Big Rocks #9
You need a hammer drill...
Actually you need a rotary hammer, which is a lot more powerful than a plain old hammer drill. People will sometimes say "hammer drill", when they really mean "rotary hammer", but the guy at the rental yard will give you the wrong tool if you ask for a hammer drill.
/ Moving Really Big Rocks #10
NHbotanut, i'd like to see pics if you can find them. I may have to do this some time this summer.
/ Moving Really Big Rocks #11
Using a rotary hammer drill, feathers and wedges you may be able to split the rocks into usable landscaping material.:D :D :D
Small rocks.
/ Moving Really Big Rocks #12
I agree with the other posters, the other option with a rotary hammer is to drill the rocks and epoxy a rebar loop into them as a grab handle. Works well too.
/ Moving Really Big Rocks #13
Joel... I don't envy you.... you have gone from having exhausted your options for dealing with that pesky rock to having so many it may take weeks to sort down to which one to try;) Gotta love TBN... lots of experience and ideas :D
Hey guys, thanks for all of the advice. Here are some pics, with luck there'll be some after photos. I put a coffee mug on the biggest rock to the left for some scale. That rock has two to the right of it that are also big, but I don't think as big as that one. I also included a picture of my driveway after dragging some other biggens out of there. Between the loader dragging and the dozer pushing to dislodge the three still there the driveway took a beating. But then if it was easy anyone could do it, right?? See next post for coffee mug picture.
more pictures
/ Moving Really Big Rocks #16
I recently rented an electric jackhammer for about $25 at a local rental supply, worked great at busting up rocks that size into manageable pieces, was kinda fun but ,that thing did get heavy after awhile.
/ Moving Really Big Rocks #18
Ductape & Joel
As promised, here are the some of the pics on the rock splitting. Also, I meant a Rotary Hammer Drill.
/ Moving Really Big Rocks #19
Lets try that again,....
/ Moving Really Big Rocks #20
I really like what you did with your rock garden. Is this the first or second year harvest?
In the old old old days, they used water and wood to split them. Time and pressure is all it takes. I agree with all the other posters.
GADNER DENVER PUMP ON A SKID (A60736)
GADNER DENVER PUMP...
SCREENER (A58214)
SCREENER (A58214)
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2017 TROXELL 130 BBL STEEL VACUUM TRAILER (A60736)
2017 TROXELL 130...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2023 FREIGHTLINER M2 4X2 24FT NON CDL SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
