ML 230 Control Valve
/ ML 230 Control Valve #1
lilhoo
Prairieville,LA
Mahindra 3525
Hello all, first post here. Sure hope someone here can help. I have a Mahindra 3525 with an ML 230 FEL. The FEL control valve is leaking hydraulic fluid and I've been unable to find a rebuild kit. Surely there is on but my Mahindra dealer says no? I'm not against a full replacement of the valve but not at the expense of $700+. Any help is appreciated.
/ ML 230 Control Valve #2
Mahindra may not offer a rebuild kit but the valve probably has the ability to be disassembled and fixed. It is possibly just an o-ring , copper washer or similar easily procured and replaced item. My personal experience with leaking control valves has twice been that the leak was caused by an easily replaced o-ring and once a copper washer. This may not be your current issue but I would attempt to see where the actual leak is, take that section out/apart and see if there is a ripped/damaged part you can find a generic replacement for.
/ ML 230 Control Valve #3
Any GOOD hydraulic shop can match some O rings and/or backup washers for your valve for a few dollars. If that doesn't fix the leaks, you can find a replacement 10 gpm joystick valve at a number of places for around $200. Don't be suckered into paying much more than that. I've changed out more than one, and a little shopping can save you a bunch.
Can anyone recommend an aftermarket replacement?
/ ML 230 Control Valve #5
No HV6901 Dual Axis Control for 2 Spool Hydraulic Directional Control Valve | eBay ( GPM and float position???) https://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic or Brand Hydraulics Monoblock Loader Valve, Model# PLV22TSTKAB | Control Valves| Northern Tool + Equipment would probably be a good replacement.
I have had extraordinary luck purchasing hydraulics on Ebay. The last two control valves I bought were NIB and less than $50 each...1 was a 3 spool the other a 5 spool. (probably about $1300 retail value together) Patient, careful watching and using every conceivable hit word search for the item ( including common misspellings, like "hydrolic") is a good way to find items that are not listed well and get few views. These kinds of extreme bargains take dedicated watch/searching though and is more suited for an item you don't need right away.
Haven't tried EBAY yet but neither Northern or Surplus have any in stock. My searches are coming up empty.
/ ML 230 Control Valve #7
Try Bailey Hydraulics. #220-957 joystick valve - power beyond capable. I've installed a number of them. $185 + freight. So far, I have heard no complaints about them.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
UM AWS-36 HEADER CART (A64278)
UM AWS-36 HEADER...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
