Might be getting back into a Yanmar
   / Might be getting back into a Yanmar #41
Did you buy the 226 from a guy on wildcat road?
I got it from a fellow off Redland Rd in Oregon City, he apparently bought the 226D and an older 30hp Kioti about a year ago from another local.
   / Might be getting back into a Yanmar #43
Johndeere, your YM186D appears to have the right tires on it. But you might want to verify this.
Yanmar specified 6-12 for the front tires while US tire stores will sell you a 6.00 x 12, a taller tire, if you don't note the difference. The wrong size would be hard on everything in the gear train.
p1740817rtire600x12vs6-12-jpg.438123
I’ll have to double check that, thanks!
Had a chance to work on the 186D last night and ran into an issue. Installed a new generator and still have the battery light on. New voltage regulator too. Looks like I’ll be digging deeper into the wiring to figure out why this tractor won’t charge. I did notice that with the key on, engine off, the battery light doesn’t illuminate. It dimly illuminates at a low idle and gets brighter as you throttle up. I’ll have to look deeper into it to see if the new regulator is pinned correctly to the yanmar harness.
   / Might be getting back into a Yanmar #46
Hmmm...could it be a weak grounding issue?
   / Might be getting back into a Yanmar #47
Installed a new generator and still have the battery light on. New voltage regulator too.... key on, engine off, the battery light doesn’t illuminate. It dimly illuminates at a low idle and gets brighter as you throttle up.
There's some sort of circuit-test module (that didn't exist on the prior models) which does a lights test after the key is switched on. Maybe its powered from the wrong terminals on the ignition switch.
Had another chance today to work on the 186D. I had ordered a new ignition switch for the 226D and figured I’d try swapping that over. Same result, still wouldn’t charge. I traced out the wiring harness and found some bad connections. Fixed those and once again, wouldn’t charge. I tried the start run relay out of the 226D, still no change. I finally decided to try the voltage regulator from the 226D and finally, it charges! All along the new voltage regulator was bad out of the box. 🤦🏻‍♂️ Now to set aside some time to rebuild the front knuckles...
   / Might be getting back into a Yanmar #49
2 good things. wires fixed and bad part under warranty. :)
Finally getting the wiring dialed in on the 186D. Headlights and work light are now working, new orange flashing lights and switch, and now the horn works.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
SHOP TOOLS (A58216)
SHOP TOOLS (A58216)
