Massey Ferguson 4608 Lethal defects
/ Massey Ferguson 4608 Lethal defects
Ok So here is the updates after Work Place Health and safety inspect the Tractor, now this will be a 3 part video set as it takes me 1 full day to 1.5 days to just upload this one video so its painful, but in this you get to hear step by step the whole thing as it unfolded from first seeing the tractor.
Garry
/ Massey Ferguson 4608 Lethal defects #42
Too much reading for me, im outa here.
/ Massey Ferguson 4608 Lethal defects #43
I chewed my way through your thread and the youtube videos, whew what a saga of how not to do things.
Comments, In one video you showed the tractor going down hill in neutral and speeding up and slowing down, my impression was the gearbox is binding. When you said that it can be adjusted by changing gear and that it does not change in 2 or 4wd, that definately points to the gearbox.
At the end of this hill you put the loader down and the front axle practically leapt off the ground, this after seeing in another video you only just lifted one front wheel off the ground at full revs. What is going on???
Also you used the term "bleed down" and demonstrated. "Power Down" would be more accurate as when the loader hit the ground it lifted the front wheel off the ground. If the oil was bleeding past the valves then the effect would have been as if you put the loader in float on the way down, leaving the weight of the tractor on the front axle.
Querrry is the joystick cable or electronic? Is the cable sheath crushed at some point? Can you disconnect both ends of the cable and test how well the cable slides in the sheath? When you used the joystick I had the impression it was very "draggy" and the joystick was not going to neutral/centre position.
Can you show the tractor jumping and stalling? This would force Agco's hand as it would be very bad PR.
Lastly your tractor has the wheels set on a narrow track. The wheels are a 2 piece design. Just remove them from the tractor and unbolt the centre dish and flip so the "hollow" faces out and refit to the tractor ,this will give you a wider track and a much more stable "feel" to the tractor. This is the cheapest option.
The 2nd alternative is to fit duals, even more stable as the wheels can not drop as deeply into a hole. Given your situation I would just do a dish flip, and save the money for lawyers.
Good luck.
/ Massey Ferguson 4608 Lethal defects #44
Fergie4608...
I'm not a mechanic and don't claim to be but have operated machinery all my life...
My observations...
Looks like your FEL joystick is sticking...
A good dealer should be able to change out that unit and fix the bucket dropping...
Sorta befuddled that your dealer could not address that issue...
As far as rolling down the hill out of gear and the jerking of the drive while the wheels are turned...
Looks like a bad valve in the control module of the shuttle...
That would also explain the lurching forward of the unit...
That is my unsolicited advise on the problems...
Too bad your dealer has not addressed your issues...
Keep us updated on the progress...
I hope you get things worked out...
/ Massey Ferguson 4608 Lethal defects #45
Yes, I was just thinking "what a long-winded drama" whilst trying to focus on the facts. I watched some of the video footage and reached the same conclusion. It needs to be brief, concise, accurate and straight-to-the-point, but was just too long and drawn-out.
There are, nevertheless, serious faults with:
a - the machine, which require rectification under warranty,
b - the Dealer's repair strategy, reactions to faults not rectified, and
c - AGCO's lack of remedial action and on some occasions delays in further action.
Could the Dealer not loan you a unit while yours was in their workshop?
I can understand Garry's exasperation, frustration, anger and worry. Add to the mix more than a few frightening experiences and it becomes a machine he doesn't want to use. Who can blame him? But at the same time, the Dealer and the manufacturer need to stand behind their product.
Up front ... all my machines are 40+ years old. They're very strong, robust, and virtually unbreakable. I've never claimed to have a huge amount of experience, but I've learnt where the limits are ..... seen the edge without going over it, so to speak.
Regarding the "drag/binding/reluctance to move" fault: Does this seem similar trying to move backwards, as it does forwards - that is, does the resistance seem as severe in both directions?
My first thought was that it sounds as though the transmission is trying to partially-engage additional gear or additional range. Up front - I know nothing about it's design. On a few occasions I drove an old Ford 3000 with a "Select-speed" transmission, and found if the lever was not exactly centred in position for the gear engaged, it would "load up" the engine heavily because it seemed a clutch or band for the next (higher or lower) gear was also being partially applied. A light tap would centre the lever and instantly relieve the problem. I suspect an internal pressure leak is the probable cause, given it doesn't occur on some occasions - not clearance problems. It is likely to be in the F-R shuttle, being hydraulically-shifted.
The steering issue has to be rectified immediately ..... that is an accident waiting to happen.
Loader control valves sticking also falls into the same category as above.
The issue of ballast weight and front axle load: I believe this appears to have been somewhat misunderstood. I can see both Garry's and AGCO's as well as all others' viewpoints, and what I think has been missed is the relationship between axle weight and grip level. The strength of the front axle drivetrain may be designed for the weight and therefore grip of only the tractor itself. While they permit the addition of a loader of a certain specification, that will significantly alter the grip of both front and rear axles. Especially with the bucket full, the front axle grip will be significantly increased. They will then be able to drive much more before before breaking traction. Therefore the drive components to the front wheels will have to cope with a higher load (torque load). Without rear ballast the rear axle grip will be notably reduced, which will only compound this issue, because they cannot "push" as much as they should. Ballast weight, wheel weights and loaded tyres are all options for combatting this problem. Stability will also be increased, as I have said elsewhere.
Lack of lifting capability is also a no-brainer - who can use a loader that can't lift any weight? I'm still amazed at what my 40y/o loader will lift.
Lurching shuttle: This also has to be rectified immediately. This is an 80HP tractor. Harsh engagement of any transmission elements (clutch packs or bands) will not only damage drive-train components, it could easily cause loss of control and compromise safety.
Bottom line - we all want to hear it all has been fixed properly.
I hope it is soon too - this has gone on for much too long.
I also note Garry appears to reside not far from me. I can only say our local MF dealer appears to be quite the opposite, but again I've only ever bought parts from them.
Thanks for that Redman135,
1 I have no clue where the binding is, I have changed my mind a few times and wondered if it could be a rear diff situation as at one point it was really hard to get the diff lock in but all that doesn't seem to be the same now.
2 It does look like at some stage it will turn legal as I did film the testing that the Mechanic did and I did tape a small amount of that when I worked the tractor but I will show that in court and once that happens then I will make it fully public at that point. See it was the dealers Mechanic so they have all the records of this so will wait till then.
3.
The loader as far as I can see actually sits on top of the actual Valve Bank, it's one of those tricky things that if I start pulling things apart to much while its under warranty then I will give them that right to wipe my warranty, now I know you could argue that they are doing nothing at all now, but until it officially runs out then I don't want to give them cause. Agco did send me an email to say that their 2 men would be here Monday to inspect the tractor but I never recieved any notice on Friday so I have my doubts.
I know this seems nutz but the Head of Technical Support said that widening the stance will cause more load to many of the failing parts of the tractor like the front Diff that blew so again I am not keen to alter to much, I will keep the pressure on them with this publicity and even add to it shortly.
Thank you so much for taking the time to look into this.
Garry
Turbys_1700
Thanks so much for that, it's way past the dealer now to the point that I only deal with Agco Australia although nothing at the moment is happening there, they are supposed to be inspecting the Tractor tomorrow but I did not get any confirmation as to this. Its the damage that the Fualty Shuttle caused and the other Faults that mean the tractor must be replaced as it's that reliable, Your 100 % on the money that they Dealer is to Blame, but then I have had to Contact Agco 20 times with such terrible response, that I still can't believe their way of dealing with it, But I will let you know how it goes from here.
Garry
/ Massey Ferguson 4608 Lethal defects #48
The statement in point #3 where they say there would be increased load on the front axle is correct. The real question is how much extra load?
Widen the REAR wheels is what I meant and would still do for saftey reasons. In all your posts there was no mention of rear axle problems, only front axle trouble. The extra loading would still be less than with dual wheels. My father ran duals on his 178 for 26 years with no axle/bearing trouble
Worst case if legal action fails or you just don't have the money for court, can you swap in the 12x4 mechanical gearbox (not multipower) this would get the tractor safely mobile,leaving just the hydraulics to sort.
3.
Garry
/ Massey Ferguson 4608 Lethal defects #49
I read your whole thread and saw the long video which started at the shed area and went to the mulch pile.
To be successful at getting what you want, IMHO, you need to cut way way down on the rambling on verbal, endless, no paragraph breaks writings here on TBN.
You're NOT helping yourself in this way.
Here's what I suggest you do. IF you're going to write things here find a way to break it down; maybe have someone else edit it BEFORE you post it. Whether dyslexic or ADD or something similar of both, people need to be able to understand what you're trying to, or are actually saying without having to read War and Peace in it's long version....
DON'T post corporate letters here with company letterheads and Agco corporate people's names; you could easily have this turn hard against you, and be sued for slandering people in a public forum. What you say about people ripping you off, the salesman lying etc., and your dealer being incompetent, etc. IS actionable if they want to make a case. Remember, they have more money than you will ever have, and if you piss them off enough they will come after you to stop you in your tracks, EVEN if you are right about what you are saying.
The thing is to be smart about how you go about getting what you want.
I empathize with all your dealer and Agco gripes/concerns and valid worries about being hurt and wanting other to know about it. BUT, when you chase after a corporation and say what you are saying is facts; it's not really facts, it's your OPINION. Your opinion is important, BUT it's not facts you've detailed, so much as your personal experience with your MF tractor.
You can decide to continue with your relentless pursuit of MF/Agco, etc., BUT ask yourself, do you really want to spend all your time doing this, OR do you want resolution to the problems with this, what seems to me to be a big LEMON tractor?!
If it were me I'd want resolution.
1st, they're NOT obligated to give you another tractor. They ARE, while under warranty required to fix issues through their dealer network; that's about it. You keep slamming the selling dealer relentlessly, and that's not helping matters either. They tried to fix the tractor at various times and haven't done a good job by anyone's standards. That's one issue. Dealing with Agco is another. Their letter and so on is still another.
Here's what I might do if I were you.
I'd contact whomever you can talk to at Agco and tell them politely, very politely, that you would be more than willing to accept what they consider to be their best offer to you to buy you out of your ownership, give you a replacement, similar model, brand new tractor for you to cease making ANY more videos, or writing anything about them on any internet forums; and you will sign a letter saying so when they exchange your current tractor for a new one.
If they won't agree to that offer from you, what do they see as a satisfactory to both parties solution to your problematic tractor. Let them tell you what they would be willing to give you, basically in exchange for your silence going forward.
You don't have the power you seem to think you have. Right now it's a stalemate- you think you're kicking their azz with the videos and such, but you're not. They can hold out until you go completely berserk from frustration, or get hurt when something goes wrong with the tractor. As it stands now they've cut your balls off of your tractor and rendered it less useful than a rock. They can just run your warranty time out and leave you stranded by the side of the road; oh wait- they already have.:confused3:
See my point- they have the power. You have a broken tractor- which could easily be referred to as a lemon. It IS in your best interest to try to work something out with them, but for you it WILL take listening rather than talking at them. I suspect they are tired of listening to what you have to say. Use constructive psychology and give them what they want - you to shut up and go away. If you give them what they want, you could get what you want. You'll never win a court battle with Agco; they'll bury you, and the tractor in a hole their profits dug long ago.
Trust me here; I've gone to bat for tons of people here on TBN, and it hasn't just been for Kioti tractor owners. I get it, buying what turns out to be a lemon sux big time. Salesmen lie all day long, dealers tell customers whatever they think you'll believe all day long. Dealer and other mechanics do what the service manager tells them to do, and often get it wrong. Manufacturers make mistakes and sometimes the engineering is crap, the machine is a lemon, or a Monday or Friday job and the retail customer gets screwed. The World isn't a fair place in way too many ways, BUT if YOU want this issue resolved you have to get them to want to play ball with you. The direction you're going currently they don't want to, nor do they have to meet you halfway.
Slow things down, write clear, concise sentences, edit what you write, or get someone to do it for you. No harm in enlisting help to get the job done.
I'm with you, even though it may seem like I'm being harsh, I'm doing my best to give you constructive criticism to get you some perspective on where you stand with this situation as an outside observer.
I'm hoping this helps you. I agree it sucks and I feel for you and your farm and livestock/horses, etc. It's NO FUN having a broken, useless tractor. So what are you going to do to get it resolved- so you make forward progress, not spinning your broken diff in knee deep mud?!:thumbsup:
Wow, Coyote Machine, That's Fantastic advice and I don't in any way see the Harshness, as I can see what your saying in between what I am trying to get resolved. I have said enough in relation to how it all fits together but when I got told last week that I can't use it anymore here then I feel as though in Australia we need to know that because our laws actually make it an offence so many people will be unaware of that particular problem.
Can you tell me about the Kioti Tractor are they poor quality?
The only thing different that I would say is that in those ramblings many people have come forward with their stories and some have very expensive equipment but Agco left them hanging, So to that end it does help for people to know who and what happened so they don't buy that equipment, There have been far bigger giants then Agco will ever be that ended up with the same attitude to the end user, they took businesses that could not be busted all the way to extinction which is where they should have been. I know it's not the best way to look at the situation but if we do not talk and pass on experiences then there is no chance of Change. The Manufacturing industry as we know it world wide needs checks to stop us drowning in poor quality or Much worse Good Quality thats badly handled. I Truly thank you for even taking the time to help me see my mistakes and also the goals here.
/ Massey Ferguson 4608 Lethal defects #51
Fergie 4608,
Thanks for seeing where I am coming from. I'm on your side, I totally get it we're all buried up to our necks in ***** quality half-azzed products that are unsafe and pose life threatening dangers to unaware buyers and owners. It suz big time, and yes we do need to make noise or we will just keep being rolled over by corporate think a-holes.
As far as Kioti goes, I've owned two since 2009, never having owned a tractor, and not being a farmer, or growing up using farm equipment so I learned that my first DK-35 3 cylinder diesel was a little underpowered for what I needed it to do FEL capacity wise. I traded it to my current 4 cyl, DK-40 and have basically been satisfied since.
When I say I've help people here on TBN with Kioti and other brand tractor issues, I have some extensive automotive, electrical and mechanical experience under my belt, and I try to get people on track with their focus as to how to get their issues resolved. Every tractor brand has some issues as does any electro-mechanical piece of equipment, but I feel Kioti does an excellent job of manufacturing mostly trouble free tractors for the price point they are selling them at.
They go up to 115 HP now, IIRC. Here's an idea to ponder: maybe if you could walk away from your MF and recoup most of your initial investment, a Kioti, (or what may be referred to as a Daedong, (Kioti's parent co/manufacturer from S. Korea) tractor in AU. would get you back to being a satisfied tractor owner? I'm fairly sure there are a number of Aussies here who have whatever Kioti calls itself in your part of the World, and are mostly happy with their tractors.
Back to your current tractor dilemma: I really think you do need to keep at it with Agco, but maybe less confrontationally? If you could get them to make some sort of satisfactory solution to replacement of your tractor- even if it means you contribute something toward a bigger or different model possibly?
I don't know what the exact solution might be, but why don't you say here what exactly you would want for them to do for you and maybe collectively we can find a way for you to get it.
BTW, I'd really like to visit your part of the planet some day. I hear it's a fun place to hang out and I often find Aussies in my travels in Europe and elsewhere. Most are out on day passes from the colony!:D Just kidding, of course!:laughing:
I am still wearing my Ball and Chain as we speak, I would really like that if ever you want to rock on down it is a Very safe place not like the rest of the world is these days.
Agco reps are supposed to be coming today so yes I took your advice and toned it down and I offered them a soft version of what I would like to happen so as to try to get something offered, So will wait and see how we go from here.
I have a company that has been pushing the Kioti's tractor and they rav about how good it is, Look Hyundai's are unbelievable and the things that Korea make are definately good enough quality by a long way, they list people using them in all sorts of different works so some have huge hours in work under there belt. The only thing I felt was that the diff didn't look as large as even my Massey and we are talking about a 100 Hp I was looking at, now having said that he said the way they do their diff is the strongest design. My Tractor work really is mostly loader work and Slashing/ Brush Hogging so its not ploughing deep under huge loads, and for getting access through Muddy terrian. It's funny that I draw so much from the supposed security of new, and of Brand Name.
I can tell you that if the dealer had fixed the issues on the tractor in the first place I think the damage may never have happened, but saying that, the Binding is definately cause by them in some way so I guess that is irrelevant.
I am very concous of what price bracket you buy in rather then expecting a Kioti to be as trimmed out as a $120 K top model of the leading brands where in nearly every case I see, they are actually double the price of the cheap range in the same Brand line.
Well I guess today I will get to see what ends up being the fall out of this, I think from everything I have heard from many people, Agco has a hearing issue and that is when its difficult they just run and hide in the corner rather than even looking at the facts to see whether something is a small problem being made large or it is a large problem growing that a very small amount of effort now will totally fix it, their feet really seem to be stuck in the mud in Fear rather then Growing. It's funny how many Brand loyal Customers they have alienated with their in action, Just like me how many promises they make and never intended to call back or follow up, That is the biggest thing I hear of everyones complaint that is world wide, their marketing is supreme so like my tractor they bring a completely new platform through and they are going to have bugs, I don't have a problem with that, and I can understand they are learning as they go but at the end of the day they must be talking to their customers and that is something that no one at Agco are doing, and then they will promise you the earth and abandon you straight away from there. But I guess that is the real point isn't it, I am talking about things because I care about the name and they simply have to many hassles to bother with all the others and that is where they are at and expecting something different rather then adapting to get what I want from the system is smarter then smacking your head against that wall.
So where about's are you in the world?:mur:
/ Massey Ferguson 4608 Lethal defects #53
1st of all, I wish you excellent results when you deal with them. I suggest no matter what try to keep your temper, and be the better man about what they offer, or don't. They're going to do only what they want to anyway, so you may or may not have any influence in their doing what is right, vs. just doing what they feel like you may deserve, from their POV.
And in the end they will show their true colors; and you can then step back and make your decisions about what to do next without getting into a pissing match.
I get that the safety issue is a big deal and so for that matter is how they deal with faulty product remedies, BUT you have work to get done and a life to live; which unfortunately for all of us is too short to waste too much time on fools and idiots who just don't get the picture of what treating customers right is all about. You've brought to a lot of people's attention the dangers, but ultimately you have to take care of # 1 and that is YOU and your farm and animals.
Kioti diffs may not look as strong as some other brands from a visual perspective, BUT I can tell you that the parent company, Daedong is a major manufacturer of heavy equipment in their part of the world, and like Kia and Hyundai, they are coming up; like Toyota did in the day from Japan.
In my mind, and from my use and experience to date, and I have logged over 1500 hours on my two Kiotis, with a 1000# subframe backhoe attached as rear end ballast, their tractors may not have all the bells and whistles that some brands have, but for their price point in many instances they actually offer more as standard equipment instead of having most everything one wants/needs as a pay extra option. In Canada, for instance it's this pecking order: Deere, Kubota, Kioti. Being third is not too shabby considering what their competition and pricing is on the top two. There is hardly anyway that one would be able to buy into the top two in a ag level tractor for what one receives in a Kioti, for the money spent, IMHO.
I'm almost certain you would be really amazed at what an 80-100 HP tractor Kioti would provide to fill your needs around your farm. Why not check out the Kioti owners forum here on TBN to read about those who own Kiotis and their level of satisfaction with their machines?
I'm in the USA, you know, the place the Russian's bought lock, stock, and barrel recently at auction!?:laughing:
G'Day Mate !:thumbsup:
Oh Matey, So are you moving out soon:confused3:
It makes me sick at what all our service men and women sacrificed and where our Countries are now but then I guess the same arguement applies that we won't be able to change it.
I will have to talk to my Wife about all of this stuff and see what comes back about it from here. I feel allot better talking to you, I am a big Hyundai and Kia Fan, Korean Sth Fan, I think allot of the other rubbish is actually that in Tractors so I am cool with it having what I saw in the tractor. I will keep my mouth shut until they tell me what is the direction they are going to take, but I won't tip my hand as the dealer that now is going to fix the tractor is the same one that sells both Massey and Kioti so if I start talking to soon it will cost me money either way, and I can't get rid of the tractor until its fixed !!!!
So they saw all of the faults but the steering is random and I believe it's caused by something else which seems now to be the Shuttle, as the loader and rear spools are on their own circuit where the other one share the Shuttle which is the way it showed up many times. Oh well time will tell.
/ Massey Ferguson 4608 Lethal defects #55
Thanks Fergie,
I don't know what to do as to the States. I spend about 3 months a year now outside the States in the islands to avoid winter here. I'm able to claim Canadian citizenship too as a dual citizen of both countries, but what's left of my family is all here in the States. I used to have relatives down under, but never got out to see them; they were one generation up from me and are now likely long gone....
Oh well, we can talk further another day about this stuff...
It occurs to me that instead of pushing for a repair to a lemon I'd try my best to get them to just take it back and see if you can move into a right sized Kioti. I think maybe a 90 horse or thereabout would do what you want it to. I'd approach it as; ...'this is what would make me a satisfied customer- that you, MF and Agco took care of me, and I just chalk it up to a situation gone wrong for whatever reason, no hard feelings'. It can't hurt to ask- the worse they can do is say no, and that still doesn't stop you from getting a different brand eventually.
I feel strongly that no matter what they do to your MF it will never be right. It is a very unfortunate situation, but you got lemons so you have to make lemonade out of it, somehow.
They might even be glad to have you gone from their radar completely into another brand; and I'd be amazed if you were disappointed in a high end Kioti of the HP range you need.
It would be a fresh start, and who knows what they would do with your existing tractor. It would probably end up in an auction and be sold as is, no warranty, so they can completely wash their hands of ever knowing about it....
If you and they can walk away in different directions and call it a day, everyone would 'win' in so far as the situation being over once and for all, and that would be huge for you, in the long run.
As an example I've got a Husqvarna AWD 322T Ride mower that I've owned for about 2 seasons now. It has 2 transaxles, and the front one came out of the factory with a palm sized glob of silicone jammed in at the axle shaft. It leaked like a sieve. It never should have left the factory floor to be delivered to a retail customer! I had it replaced under warranty at about 30 hours. Now I've got just over 100 hours on the machine, in it's second season of use and the new trans is leaking oil. I don't even want to deal with it because I'm confident they will say it's off warranty and so on. It's a small investment of under $6000 total cost for the mower, BUT just like your MF tractor, I'm supposed to replace the transaxle every 70 or so hours?! What kind of nonsense is that? I will document the fail on video and with pics, take it to my selling dealer, ask them to bring the Husky regional rep in to play and see what happens. I expect nightmare and excuses and being told I'm out of luck- warranty expired, sorry sir....
Just like you I can't just park it and not use it, or go buy yet another mower without some resolution to this one's issues. Man I just hate being in the situation of being at the mercy of manufacturers who put everything onto us, the retail buyer. I've had similar situations with Electrolux dryers, Viking pro grade beverage coolers, Waste King disposals, Buderus boilers, the list is endless, and I know in NONE of these situations am I at fault in any way. I buy the best I can afford, and do research into the product before buying.
In the case of the cooler my selling dealer gave me a different brand, U-line, no charge, even after Viking replaced the original, no charge with a brand new unit, that also failed miserably. Waste king replaced the original disposal which just locked up while under warranty with a new one. Then sent me an email telling me to discontinue using the new one because it could implode sending shrapnel all over the place!? Again a new one, at their expense and labor to remove/replace it.
It drives one nuts just having to deal with all the broken crap products that these companies keep spewing out at us. And, like you I'm not one to take it sitting down or just lie down and take the beating. I try to reason with them once I have someone to listen, usually via email, since they can't escape the paper trail. And in the end, just like with your MF, they just want me gone from their lives so they can beat the next 'customer' with the big corporate stick - which surprisingly most folks seem to just take the beating?!:confused3:
Anyway, I'm really hoping your meet with the reps goes well and in your favor. I anxiously await the outcome....
Let us know what's going on....:thumbsup::)
/ Massey Ferguson 4608 Lethal defects #56
FWIW, with my 40 HP Kioti it is a HST model, not a shuttle shift like yours. And all the hydraulics are going from the HST reservoir and I believe 2 separate pumps. One pump controls the power steering and so on, the other controls fluid flow to the FEL and transmission functions like the H,M,L of the range selection for moving the machine at a certain 'gear' ratio/speed. The previous is from memory and could be incorrect but here's my point:
So it wouldn't surprise me if any power steering issue you may have could be tied into the pump that also could power your shuttle shift, i.e. it all goes in and out of the same fluid reservoir(s) and when/if they detuned the machine to render the loader gutless that move likely affected other systems too.
Now consider that in a World gone right, they might be able to 'fix' all the issues with your MF. Somehow I doubt it, what with their track record so far....
But, it may be that they want to have one more go at it- to which if it were me I might say, have at it, but if I go to pick it up and it's still weird, I'm not interested, and just give me a credit toward a Kioti at the dealer you mentioned and wipe out my loan, or some such game plan that they will agree to so you both go away feeling not so screwed.
/ Massey Ferguson 4608 Lethal defects #57
G'Day mate! What's happening on your end? Progress report please :)
Coyote Machine,
Sorry Matey sometimes this thing tells me when someone has made an entry into it, and obviously other times nothing at all, so I have not been in to check.
Ok Statis report is I have had legal advice and that is going to prove to be very interesting in a very short time, I believe that Agco is going to be finding my phone number very shortly.
1 Agco attended my Property to test and check tractor they spent approximately 2 hours here and found all of the Lethal defects that I had reported to them many times. According to the Manager of Tech Support his Laptop Failed and he could not find my details to contact me to arrange the visit on the Monday, which I find extremely strange but they came here on Last Tuesday 18/07/2017
Item 1 they had me demonstrate the Binding on the 45 Degree slope and were speachless, the Rep said in his defence, all he had to work with was a flat car park I had warned them about that Fact, I said that is why I offered, That before work was carried out, they atttend real time operations here, so I could show the defects in a real time work enviroment, which they ellected not to do. He Felt Brakes might be Dragging so he hoped on, and spent an hour dragging against low range, stabbing the Brake pedal to release, a possible Jambing brake, this did nothing but wear my Brakes out, now my Brakes are stuffed and the pedal goes to the floor, and is needing adjustment, I did say its been 5 months with this Dragging and I have had no Brake wear in that time, in one Hour I have no pedal left, and he did not improve it in any shape or form.
Item 2 the Loader, He could not belive the loader function it Jambs in the Float position, and it sticks both up and down, he also says there is a restriction there somewhere that I cannot get full up, He said that when the dealer split the Tractor they obviously did not put that back together correctly, he did not comment on why the Loader Valves stick both going up and coming down but did say it needs fixing. He also did not check the lift capacity of the Machine while there as they had nothing to use.
Item 3 The Steering just completely dissapearing has Agco completely Baffled but I did learn allot from all this stuff in actually dealing with them, Agco feel that the steering is a rather important function and that is why all the other hydraulics are on one circuit and the Steering only share function with the Actual Shuttle, I always thought the steering dissapearing was related to SHuttle then Loader trim = no fluid left for Steering but from discussions with the experts it appears that its Shuttle that may rob Fluid from Steering, But today I actually have a much more likely idea of the failure but will save that one for more testing.
item 4 is the Tractor stalling out on hills, robbed of power by Hydraulics and then steering, they say they need a Dyno and much more research on that.
Item 5 The Binding is getting worse as winter continues, this was when the diff blew originally and although I am not doing hard work with the tractor at this time, it concerns me that its increasing, they say more research and study needs to be done.
Item 6 I say this tractor is like a different animal every time it is started, the Hydraulics can never lift like before, but then sometimes can lift something, and its random, Many of you have said and I agree is the Pump going bye Bye, its like sometimes there, and then not, so again its more research.
IMPORTANT IMPORTANT.
At this point there is moves to talk about Replacing the Tractor, But I believe they are considering it to be a financial adjustment which is not actually going to happen that way. With the Advice I have recieved what I have been told to do has about 4 steps to it, 1 is to increase the Safety warnings through here and U Tube and social media as it is my Responsibility by Law for my Duty of Care.
2 I am to Send a Letter of Demand Directly to Agco
This is a game changer to anyone with Serious Safety defects in Products supplied by Agco or any other dealer/ Manufacturer
3 with that letter I am to CC the Federal Minister for Ag in Australia into the correspondence, also My Federal minister for my electorate, My State Minister, as well the ACCC, Work Place Health and Safety Australia in All States, Office Of Fair Trading, Being a Battling Farmer does mean that many of these people are actually surprisingly keen to be seen helping the Small guy.
4 is then to forward all of this including my Official complaint that I gave to Work Place Health and Safety to the Media and in that all of the Correspondence to Agco and the 4 times that they responded in 21 months, to Main Stream media, that is Television, and print media. Given that these are all serious safety breaches then the feeding frenzy will be intense and the fact as I said before that each time they recieved a notice of intent and an offer to find a solution does not look Favorable that they ignored completely their duty of care responsiblities with no correspondence, not does this little Fact, they attended Tuesday, I wrote On Wednesday and still have heard nothing from them at all. It proves their complete dissregard for my Safety from the Product that has been found by them to be defective and By agencies that are responsible for Satey to be Potentially Lethal to oppertator and other persons on the Ground.
I expect this tractor to soon be replaced in a deal, I will let you know the outcome shortly.
My Post here is not for the repair of this tractor or the Faults of this Tractor but the Safety Hazzard it poses to people operating it, it is also to educate people in how to get Agco to Fix things and Dealers that Fail Customers, as has North Pine Motors Qld have done with this specific Tractor. Now I know so Many of you worry about being sued, But when the defects are lethal, they are proven, and now once again, have been seen by Agco Agents, then its my Duty of Care responsibility by Law to inform you the Public as to the Failings of the Parties responsible for the repair, and the Safety of the Product they sell.
This is important to understand that Agco for years have been ignoring people and have gotten so good at it in my case that they consider me to be a bad guy, But what they Fail to acknowledge at their own perile is this Fact, Each time I contacted Agco Australia with Emails and Paperwork I listed the defects and I also listed the lethal nature of the defects, I then contacted Agco Global in USA and gave them the same information, as this is a serious breach of Health and Safety, I can State to you, that as of the 22/07/2017 I have not been contacted by Agco USA or Agco Australia to resolve these potentially lethal defects, On Monday the 17th when they were supposed to inspect the Tractor the Manager, at sometime prior to that date, had a laptop melt down and lost all my emails and contact details. They must have also forgot which dealer sold me the Tractor and all of the other details, I know for a Fact that Agco USA had been in touch with Australia at some time Prior to that date as some of the Facts quoted to me, where related to information I had given there.
I was contacted yesterday by the other dealer, that they are supposed to be using in the future, He said that Agco said that he was supposed to come and look at the Tractor for the purpose of quoting the replacment of it and Agco are looking at some help, this will most definately not be a suitable option and needs serious rethinking on their part.
Now I know you all hate my long winded story but, Agco Attended Tuesday, I wrote Wednesday to list all of the Faults and again, specifically how they are life threatening, and its important you do this, because when it goes to the next level, this is how they judge neglegence, It does not matter that they do not respond, I can prove I wrote on that date and by them not responding, if they were to take action against you, which they will not do, because Court will look at all your attempts to find a solution and their not responding, Shows how seriously they considered your safety to be to them.
Agco is so used to people just giving up, that they use this tactic all the time, I have had so many Hundreds of stories from average people who should have been looked after, but instead they Gave up and just took it. When it is a serious safety breach then I cannot stress to you enough, Document it and Keep my details as I will help you find the door and then Kick it in. Once one person sorts this mess out then others will have a much easier time of getting Justice. Even if I got nothing done about this, even if they never replace this tractor, its been worth it because of all you amazing people and the knowledge that I might just save someone elses life or even Families Hardship that we have suffered. Knowledge is the most important thing when faced with injustice.
So My Dear Friend I have given you the Short Version :laughing:
I really think Jeepcj7 needs a big Cuddle cause he is getting Jealous :laughing:
Seriously to all of you, I know it seems painful and its a awefull lot of reading, but the lessons learned will save Many People Many thousands of dollars in the future, as well as My sincere wish is that we get better and safer Products that are backed up as they should be, those doing the wrong things by Customers, are brought into the light and those doing bad things end up without customers. Your Safety is important to me and that of your Families.
At least you didn't say get a room, I am sorry this has dragged on so long and is a war and peace novel but sometimes it takes allot of persuasion to get action from Giants, Thanks jeepcj7
