Massey Ferguson 1740M Hydro: LOSS OF POWER when hot!
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #181
I wonder if it is worth looking into other brand of injectors or not? The Shibaura N4LDI appears to the use the Denso 1160 injectors which a set of 4 are around $1600. Significantly cheaper. I know they use this engine in a ton of other equipment and not just these Massey compacts.
  • Good Post
Reactions: JWR
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #182
I don't recall has any one relocated or added a fan to cool the ECU.
BOY! That is a good question given this puzzling history. It might not be going so far as to kick into what we think of as a "limp mode" well known with cars and trucks and yet might be having a "cut back the power" mode of some sort ... probably described nowhere in public literature. Wonder if the dealer or anyone in the picture has really studied the 4 inch thick shop service manual? I've tried that on other model MF tractors and it is not easy to do. Depends on the problem of course. One would think such a mode would not happen unless the engine is overheating but that sensing and reaction stuff with an ECU is very obscure to us mere mortals...i.e. might be combinations of sensed conditions.
I'm currently researching the injectors and possible 3rd party (aftermarket) distributors. I'm not saying the injectors are the issue, just doing my pre-search research. Cost wise It looks like $449(ea). Lots to be done on my end before I make this info fully public (as to not give out any false info).
I know these aren't as sophisticated as our automobiles, but if we did have a limp mode, shouldn't an idiot light of some sorts come on within the dash?
hmmmm, I see about 12 possible lights (all dimmed out) in the cluster dash (right side).
No lights (other than forward PTO light) has ever come on while mowing and the power loss occurs. Here's my dash and idiot light lineup and we do have a "Caution triangle" one?... (I kinda think this is a safety warning however)
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #186
I still don’t believe it’s the turbo.
I still don’t believe it’s fuel injectors.
All your symptoms point towards a sudden, serious lack of fuel. Turbo definitely won’t cause that, neither will a bank of injectors.
Your engine is thermostat controlled, water cooled. Working it hard snowblowing should result in just about the same equilibrium engine temperature as working it in July.
What certainly WILL get hotter in July is all the electronics, not cooled by the radiator.
Again, CPU controllers, sensors, and pumps.
Putting a heat gun momentarily over electronics is an old school, but successful way to find intermittent heat related issues. Conversely you could put a well prepared bag of ice over suspected electronics during hot weather, and see if your issue vanishes
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #187
I have questioned if the electronic solenoid for the pump or the ECU may be overheating, haven't tested mine specifically. The injectors themselves are electronic
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #188
this, in my opinion,is 2 very good ideas.
I wouldn't rule out any electronic component [over-heating] causing failure. A few weird things to throw into the mix...
--Tractor mowed hard in past Julys, and with the A/C on; for the first 4 years. Flawlessly.
--You stop it for just 30 mins, rest it/cool it (ever so slightly when it's still 90F out) and you will get 5-10mins of full power again. Rest it for an hour, you may get 10-15 mins of normal power.
--The A/C (on) definitely kicks in the power loss sooner, opposite for turning on the heater (full on) then you get maybe 10mins of extended full power run time, so I would definitely rule out any in-cab or dash (or under steering stem - fuse box area) mounted electronics.....
..... Heater on full is tough to do (in 90F) especially with a cab tractor, even with some windows opened. I do experience longer run times however with the heater full-on and noting; in 50-60F (Fall weather), this method is my go-to and I then can mow 2.9 acres straight with zero power loss. So Fall mowing w windows open is still quite warm, but tolerable, especially when it gets the job done in one run.
So yes, I agree that electronics are sensitive to heat. This however will be a bear to nail down. I personally don't want to have a heat gun aimed intentionally on possibly good and working circuit boards or modules. I cannot risk potentially adding in another problem, or down the road. This is just too risky of a "process of elimination" especially with a tractor that seems like it's already walking on pins and needles.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #190
Just add a 12 volt fan blowing air across the components.
I can do this without harm :) now just need to know locations of where and what to cool.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #192
Start with the items that are the easiest to access then work your way down the list.
Note: if your luck is like mine it will be the most inaccessible item there is on that tractor…
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #193
if there is a distinct module for fuel delivery I would start there. just opinion as I do not know anything about this models fuel controls.
I know not to start out with non-related components like the lighting or dash modules etc., and yes, the more accessible ones first. (y)
It's all about the locations of each and what each one does. I don't have a schematic layout of the 1740M tractor to define these things. The user manual is basic at least for this level of detail needed.
I see some black boxes, a few even under the dash, I'm assuming fuel delivery ecu's (if we even have this) to be under the hood. In looking there, it's a hot mess with no text on the boxes. It would take a lot of tracing any wires connected, limited space makes on this 95F day a no deal. But in reality, that's the weather I want to trial and error this module/electronics over heating theory.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #196
How much trouble to remove the hood and let the engine heat escape, then just direct a good fan on the dash modules.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #197
for that matter maybe run it w/o hood to see if its ok then? may prove heat getting trapped somewhere causing the issue.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #198
If your 1740 is anything similar to my 1736 I believe all the control boxes are located behind the dash, I know for sure the ECU is. There may be electrical connections and sensors close to the engine that could be subject to temperature fluctuation.
As suggested, maybe running with your hood off is a reasonable test, if you have a few people to help remove it.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #199
I will try the hood removal. It's too big a chore for my 98lb wife to help with, but I can seek a buddy easy enough.
Back about a Month ago, I hose blasted all the radiators and cooling fins, engine also. This is an annual / maintenance thing (remove cotton-wood, dust) but not done b/c of this issue directly ....my region has this annoying shedding from a type of Poplar tree, it's every Spring for about a week or two straight. :(
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
2014 F-150 STX (A56438)
2014 F-150 STX...
2019 Ford F-350 (A55973)
2019 Ford F-350...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Ford 8340 (A53317)
Ford 8340 (A53317)
