Making Nicer Torch Cuts ???
/ Making Nicer Torch Cuts ??? #21
Preheating is important but mostly in thicker parts, in plate up to 1/2 or so it's not that big of a deal as long as it's not super cold like in the winter.
Lots of good info - thanks. I almost wish I hadn't seen those cuts, now I really feel bad :laughing: It certainly gives me something to shoot for though. It is good to know what is possible.
gg
/ Making Nicer Torch Cuts ??? #23
I have seen cuts done on a lathe with a cutting torch that looked like glass. The man set the torch in a stand and just advanced the lathe to make the cut. If you know what is possible you know how high to aim. I like ti draw the torch toward me on short cuts because I can wiggle less. On long cuts I go to the side so I don't have to reposition as often. Ed
/ Making Nicer Torch Cuts ??? #24
Made these parts last week for a job at work, the cuts are alittle choppy but when you get that thick every single bump or shake shows.
/ Making Nicer Torch Cuts ??? #26
You did that by hand??!! That's as good as my old Linde burning machine!!
A friend of my father once told me he saw a guy cut out 4 inch circles out of 3 inch thick plate that would clean up in a lathe in one or two passes. I never believed him....until now.
/ Making Nicer Torch Cuts ??? #28
I found my cuts improved when I learned how the torch actually worked. What holes do what.
But in general (and sadly) as with the plasma, I tend to make my best cuts when it doesn't matter, and am nervous and jerky when it does!
Industrial Toys,
Do you have a link to a discription of how a torch actually works? My torch cuts used to be awful and I'm thinking of getting another one.
/ Making Nicer Torch Cuts ??? #31
Still not simple to cut plate that thick even in a table.
/ Making Nicer Torch Cuts ??? #33
We run propane it's a lot cheaper.
/ Making Nicer Torch Cuts ??? #34
Natural gas is popular too on cutting machines. If you have the right tip and the right preheat, the plate could be 12" thick and you could do a cut as nice as Shield Arcs. Thick plate cuts nicer than thin plate and if you're using a cutting machine, there's no excuse for not having a perfect cut. The most common reason for flaws on thick plate is not enough preheat. For bevelling thick plate, they often use an extra preheat torch or 2. A shop up here goes through 200 tips a month fabricating vessel components.
/ Making Nicer Torch Cuts ??? #35
In the mid 1970s I helped build a General Electric testing facility, in San Jose California. The plant was a scaled down nuclear power plant, but it would never go on line. There was a pipe welder, who could hold the torch in his right hand, and roll a piece of pipe across the welding table with his left hand. And cut a perfect bevel on the pipe:shocked:. It was amazing to watch him do that!:cool:
I worked on my torch cutting a little more. I cleaned the tip first. I adjusted the Ox pressure to give me the jet engine sound with the cut lever down. Had to lower the pressure to do that. It cleaned up the slag and got me square corners top and bottom. Still have to work on speed and angle control but I think I have gained some. This is yesterday's with the top and bottom ground smooth and today's w/o a grinder. Not perfect and there is one place I had to restart. I will try some guides next.
Thanks for the suggestions !! Any more are welcome.
gg
Did you use a straight edge?
No, that is what I need to do next. I wanted to try to set it up for the jet engine or ripping noise and by the time I got a feel for that play time was over. Beside lowering the Ox pressure I found making my preheat flame a little softer also helped.
gg
Freightliner Columbia (A63689)
Freightliner...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
Jitter Bug (A62613)
Jitter Bug (A62613)
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2021 John Deere 4044M (A64126)
2021 John Deere...
