Looking for a new welder
/ Looking for a new welder #41
If that machine can burn a 1/8'' rod on 120v and on a 100' cord I'm getting one. I had a couple of Miller Maxstars back when they first came out and they would constantly trip breakers just about everywhere I tried to used them on 120v circuits, and that was with 3/32'' rod.
I'm really hoping that the technology has improved that much because it would make my life a whole lot easier at some of the locations I have to deal with.
I have a new Maxstar 161STL. I'll try to take some pics and put them up.
/ Looking for a new welder #42
There are a LOT of other factors involved in running a welder on a household type outlet, beyond the welder, and rod.
Wire size in the wall
Distance to the step-down transformer
The ACTUAL voltage being delivered to the house at the time of welding.
If your wife baking cookies, and drying laundry at the same time as the weld occurs?
Is the air conditioner(s) on, or the baseboard heat,,,
The list can go on with all types of possibilities,
Copper or aluminum wire from the transformer to the panel (YEP, they used to use copper)
/ Looking for a new welder #43
This is an interesting thread. I’ve been gardening all week so thought I’d “experiment” for myself.
I only had a 50 foot 12 gauge cord so keep that in mind.
Conditions:
20 amp breaker
Miller Maxstar 150 STL using 110volt
Lincoln 3/32” and 1/8” rods. NOT from rod oven.
1/4” plate
80 amps for the 3/32”
115 amp for the 1/8”
I LIKE to think I can do better with a 220V welder, adjustable arc force and rods out of the oven but I’m sure a real weldor would do just fine under these conditions.
/ Looking for a new welder #44
Here’s the same welder set up with same amperage using the remainder of the 1/8” 7018 rod. This time using 220volt.
WAY easier arc strike and running of the arc.
/ Looking for a new welder #45
LNK count me as impressed- I was only welding 1/8 pieces and had my 3 in 1 turned wide open on the dial.
You got excellent penetration on 1/4 And still had more adjustment left on your welder.
I went back and found some 1/4 inch pieces and gave it another go - reduced the power and just went a bit slower with a small gap between metals using garage kept 7018 same 120Vac thru 100 foot cord.
Got to say i am surprised just how hard it was to break the weld- took at least 10 good blows and thought I was going to crack my vice in the process.
Starting to think these small inverters can do decent 120 volt welds with a long extension cord and get good results.
But just as big Barn posted above on 240vac it sure is easier to strike the arc
(and keep it lit)-especially on the big American welder:D
/ Looking for a new welder #46
View attachment 557578View attachment 557582
back sideView attachment 557583
Gave it the Big hammer break test in the viceView attachment 557584
Looks good Dan. I wasn't kidding. Just as a disclaimer, I have no idea if my displayed 70 amps is accurate. Welder is not yet a year old, but I am impressed with it. Glad to see your results confirm mine. Hope this all helps somebody. Can't wait to see what Ritothebull does when he gets his.:D
/ Looking for a new welder #47
Sure looks like it will work for me, just wondering why your running 7018 on that rusty junk rather than 6010. That's what I use most of the time in the field, my old Maxstars wouldn't run 6010 worth a chit.
/ Looking for a new welder #48
Now you guys have me curious... when I get a little time I'm going to have to put my multimatic to the test on 110v with extension cord.
/ Looking for a new welder #49
I only ran it on "that rusty junk" to show what the weld I did the day before looked like. I ground the shackle parts I welded, but didn't take a picture as I never do. I will make sure to do proper prep next time. Also, I used 7018 as I was welding upside down and that is what I feel most comfortable using. I would use 60xx if welding rusty stuff.
Lnk
/ Looking for a new welder #51
Understanding the difference between welder and weldor is a step in the right direction. Just kidding. :)
Spellcheck doesn't like weldOr so maybe it is not a word.
/ Looking for a new welder #52
AWS considers weldor a nonstandard term.
They use welder (for the person) and welding machine (for the power source).
There is also a lengthy English rationale on how weldor shouldn't be used, but I'll not bore everyone with it ;)
/ Looking for a new welder #54
/ Looking for a new welder #55
The only known animal other than humans, who weld, is the Weldebeest.
557738d1528513569-looking-new-welder-weldebeest-jpg
/ Looking for a new welder #56
/ Looking for a new welder #59
He was on Welding Web for awhile and he was either banned or perhaps he has no internet service in the wild.
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
24' 24" Canal Pump (A62183)
24' 24" Canal Pump...
2019 Bobcat E85 Excavator (A63109)
2019 Bobcat E85...
Bandit 250XP Wood Chipper (A63118)
Bandit 250XP Wood...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
