Logging Hitch
/ Logging Hitch
Lloyd,
Whether pulling the three trees in my photo or pulling the loaded wood trailer, I didn't notice any flex at all. I did have a lower arm pin loosen up on my after quite a bit of working with it. If you don't weld your pins on, be aware of checking that from time to time.
Your hitch looks great! I like the extra receivers you added too. I think you will be very happy with it!
Also, I like the idea of the grapple, but that would only allow me to pick up and skid one tree at a time and even with my relatively light tractor, I can sometimes get out up to three trees at a time (depending on the size and density).
Keep going Lloyd!
Teach
/ Logging Hitch #83
You can order the weld on hooks from A W Direct. They are online and are very easy to work with. They sell primarily to tow truck operators. The hooks cost about $5.25 ea, plus shipping. I have ordered twice from them and received them in about 3 days each time.
Mike
/ Logging Hitch #84
Lloyd, have you ever found weld on chain hooks. I've looked and haven't seen any lately.:D
From the way you are going the paint should be drying by tonight!:D
My tractor, it finally got over it's fever. It looked it's usual self this morning.:p
Located these on the web.
http://www.awdirect.com/weld-on-grab-hooks-grade-70-3-8quot-11-38wgh/hardware/
Remember to preheat the hooks to around 500F and the steel (if the temp is cold outside) and use a 7018 rod. For what its worth
/ Logging Hitch #85
I'm lucky I live just 5-6 miles from AWDirect warehouse, Going there tomorrow, to poke around a little, their showroom is actually pretty small but they have a close out room where you can sometimes find some sweet deals.
Wish I had a TSC nearby (30+ miles away) :(
Regarding those hooks, you can also get them at JD dealer.
I thought that weld on hook looked odd in the previous link, I think they clipped the picture or something.
http://www.awdirect.com/default2.asp?keyword=weld+hooks
JB
/ Logging Hitch #86
I really don't understand what is going on with the hooks.
We had to take our daughter to the doctor today, and i went to TSC and 3 other hardware stores, all they had was those soft cheap hooks.
/ Logging Hitch #87
Managed to do a bit of work last night - late into the evening.
I tacked everything together, checked forks in 2" rec. ports - off by 1/8" - than I put a level on the concrete floor - not level. Works for me.
The detail of the fork shows a stop and a pin for holding in position. I need to do another set
which will be used as a base for a carry-all.
I still have to cut 45 degree supports and weld, weld top link connector in place(I drilled two holes for positioning) add a few more 2" rec. ports, weld on hooks and add a few re-enforcing plates and do final clean prep for painting.
I am pleased with the progress so far - but when you have a great design to begin with it is easy. Thanks teach....
lloyd
PS: I try to put photos in order but for some reason they do not appear as I select them - why?
Lloyd,
That is looking good,
You are way ahead of me and Egon.:D
/ Logging Hitch #89
Also, I like the idea of the grapple, but that would only allow me to pick up and skid one tree at a time and even with my relatively light tractor, I can sometimes get out up to three trees at a time (depending on the size and density). Teach
It seems to me though that the grapple would be great for gathering together in one place the 2 or 3 logs that you are going to pull out. granted if they are all already in one place it might not be as efficient, but if you had to get them to one place and line them up, it seems to me that it would help then. Who wants to drag one log all over the place trying to get in line for a second and then a third.
Mike
/ Logging Hitch #90
teach;1606559 I am probably not going to bother using the winch said:
First, thanks for the great post, information and pictures. I will have to modify my King Kutter carry-all into your design.
I too was going to use an electric winch with my tractor but after reading many posts here on TBN about logging and winches I decided to go with using the tractor's pulling and manoeuvrability.
After a lot of research, for my specific needs, I bought 100' of 1/4" Samson Amsteel Blue synthetic rope, along with two ten foot sections of the chafe guard, from
eBay Store - BLITZKRUEG products LLC: winch acessories, misc., kawasaki
see rope specs here-Samson
I also bought a winch kit that included snatch blocks and tree saver slings. I also bought one of these cool 26KN carabineers with a built-in pulley.
DMM Revolver Screwgate Locking Biner
It's now much better to have the logs come to me as opposed to having to get to the logs with my tractor.
I recently got my tractor badly hung-up in a pile of logs. I used my snatch block, pulley and the Samson rope to easily pull the tractor out with my small pick-up. A previous attempt with a come-along wouldn't budge the tractor.
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
Fontane Lowboy Trailer Flip Axle (A59230)
Fontane Lowboy...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Service Truck (A59230)
2016 Ford F-550...
