Logging Hitch
/ Logging Hitch #61
Block pulley, yes, it hooks in the ring of the upside down hook located in the middle of the top section. It turns that the hook, being so large and upside down, works out well for a handle when moving the hitch around. I am probably not going to bother using the winch, after testing the hitch, it just doesn't seem necessary/worth messing with. Plus, having an electric winch in the woods is not best case. The wires want to get hung up on brush and its my opinion that if something is going to be used on a tractor in the woods, it needs to be bomb-proof. Probably one of the reasons for Farmi-type designs with either pto or hydraulic winches.
Teach
Thanks for the explanation. You had me a little confused there...Looks like a nice setup. Good luck with it!
/ Logging Hitch
Lloyd,
It sounds about right. The 3/16" tubing will probably be ok, so long as you use some angle supports underneath from either side of the center going down and out, at about 45 degrees. I used the extra angle from the forks I cut off to box in the top cross piece. The angle for the entire hitch is 1/4" and my forks are 3/8".
Teach
/ Logging Hitch #63
Start of project.
Did some rough drawings - always good to have a plan.
Measured everything out to get best use of materials. Realized I will only get one unit made.
I am also building an attachment for loader - pallet forks. The idea is to use forks for both loader and 3pt application.
The new band saw was slow until I installed a better quality blade.
Most of the pieces are cut. I need a few more hours of prefabbing tomorrow than I can rough tac everything together and pre-fit before welding and finishing.
I need to buy more hooks and some pin connectors for the 3pt cary all.
lloyd
/ Logging Hitch #64
Start of project.
lloyd
lloyd,
You sure are moving fast with it and planned it out good.
Sunday you was waiting on the measurement and today you are already building it.
Looking forward to your build also.
I called a metal supply today that i use to deliver to, and they said they are out, truck may deliver some from Louisville next week.
/ Logging Hitch #65
Would anyone be interested in this. It is a heavy duty grapple for sure.
/ Logging Hitch #66
That sure looks like it would hold on good.
How wide will it open up?
/ Logging Hitch #67
Lloyd, have you ever found weld on chain hooks. I've looked and haven't seen any lately.:D
From the way you are going the paint should be drying by tonight!:D
My tractor, it finally got over it's fever. It looked it's usual self this morning.:p
/ Logging Hitch #68
Egon,
You mention you couldn't find the weld on hooks, i went to a local hardware store to get 3, and all they had was the cheap ones that don't weld good and break easy, wonder what is going on.
Yea, the way Lloyd is going, he probably already has it on.
Egon, I"m glad your tractor is doing better, hope it turned green again.:D
/ Logging Hitch #69
Might be just as easy to get the clevis ones and either cut them down or weld on as is. As others have mentioned the ears of the clevis also have uses like holding 5 gallon buckets etc.
/ Logging Hitch #70
Worked until about 9:30 last night. Have to put the brakes on - flu is going through our family again.
I buy clevis hooks and cut off the end part not needed. I did a couple of test welds last year and tried to break one with a sledge hammer - no go. I need to get 7 more. I don't think I will be finished until next week. We (the guys) are hoping to head to the farm show in Moncton on Saturday. Not that I need anything!!! :) :) :)
I also need to build a wooden platform for the carry all. I am thinking something that can carry my air compressor, generator and a bunch of tools to the pasture. It should have angled sides plus full back - about 4' high. Probably should make it slightly less in width as tires. Wood be nice to be able to carry firewood on it as well as in the loader.
RedNeck,
I have one of those quick attach. I don't think the metal is thick enough to hold up over time. Could be wrong. For the cost of a couple of hooks and a few minutes. Give it a try - don't break anything though.
lloyd
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
John Deere 72" Bucket (A60463)
John Deere 72"...
2016 John Deere HPX Gator 4x4 Utility Cart (A61567)
2016 John Deere...
2012 MACK GRANITE DAY CAB (A60736)
2012 MACK GRANITE...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
