beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,661
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
If the staining of these house logs was on the outside, I would tend to think 'no major problem'. But, these stains are pretty clearly from water coming in from the outside, and all the way through the log joints to the inside. This means that the water is and has been between the log joints. Much more serious to me than just some superficial staining. To me this is all the way through the logs at the corners and as well, around the windows and down through the walls. One can choose to ignore the signs that are evident, and some probing should be done to make final determinations of soundness of wood.
Clearly a poor design for log (which is easy to do, IMO) construction.
