loader swap
/ loader swap #1
Tony G
Manchester TN
Case 585
I have a woods dual #195 loader that I want to install on a john Deere 2020. The FEL came off my case 585 which has "open center" hydraulics...my john Deere 2020 is "closed center" hydraulics. Will the that be a problem? The FEL has a joystick two spool valve.
/ loader swap
Guess I am confused...(again). My woods loader came off an open center tractor (case 585)...so are you telling me that the joystick valve is matched to that open center hydraulic system and I will have to purchase a another joystick valve designed for a closed center (JD 2020) tractor
/ loader swap #4
What I said was to check and see if your valve can be adapted to a closed center valve, and if yes, then all you need is a PB adapter and plug or a closed center plug.
If your valve is not convertible, then you will need a new valve.
Do you know the brand and model number of the valve?
/ loader swap
I will not be able to check the valve till tomorrow, but; now I understand you although I don't think I will be able to tell wether the valve is convertable or not. Thank you...
/ loader swap #6
If your open center valve has 7 hoses, it has a PB port, and there may be a closed center plug for it or just plug the PB adapter.
/ loader swap
Six hoses ...looks like I'll be buying one of those valves you suggested JJ.
/ loader swap #8
Look more closer and see if there is an unused port. Someone might not have known to use a PB port even if the valve had one. It is usually located through the center of the valve.
Can you show a picture of the side of the valve with the return port?
/ loader swap #9
Tony G
Yes you'll probably need to buy a closed center valve as some of the older open center valves only had 6 openings IE no opening for power beyond.
/ loader swap
I looked yesterday JJ...no extra port. Now fellas, can I use the cheaper valve? My tractor is 10gpm which is top on that valve...is that ok...or do I need to upgrade to the 13gpm?
/ loader swap #13
TThe pressure valve from the factory is set to 2000 psi, so you need to set it with a hyd gage to your tractor specs of 2250 psi
J_J
Actually on a closed center system such as the 1020 the pressure relief valve on loader hyd control valve can be closed completely as the stroke control will control the pressure. The non-convertible closed center valves I've seen have no built in pressure relief valves
/ loader swap #14
Yes, I agree that none of the valves used in a closed center hyd system need a relief in a closed center hyd system.
If the valve does have a relief, just set the valve relief to say 3000 psi so it will never open, and the pump relief will dictate the relief pressure.
You might say how do you do that with the tractor relief set at 2250 psi. Well, when it gets to 2250 psi, just crank it down more about one full turn should work. Maybe use shims if you have to.
/ loader swap
Valve ordered (back ordered)...they said in @ two weeks. I will post an update when I get it. This will give me time to fab the mounting brackets. Thanks for the help guys.
/ loader swap
Update...10gpm valve is no longer available...they are sending me a 25gpm valve. Will that be an issue?
/ loader swap
JJ ...right after I spoke with the tech service rep; I pulled up your post to double check witch valve you recommended. Anyhow I immediately called him back only to get his voice mail. I told him about your suggestions but he did not return my call and I received a notice that the larger valve has already shipped. Guess I will iron it out on Monday.
/ loader swap #19
If you can swap it out with no hassle, do so.
That valve will work, but you will be at full flow at about half lever.
You will not have the finesses if feathering.
A valve matched up to your flow in GPM's is best.
