loader swap
/ loader swap #13
TThe pressure valve from the factory is set to 2000 psi, so you need to set it with a hyd gage to your tractor specs of 2250 psi
J_J
Actually on a closed center system such as the 1020 the pressure relief valve on loader hyd control valve can be closed completely as the stroke control will control the pressure. The non-convertible closed center valves I've seen have no built in pressure relief valves
/ loader swap #14
Yes, I agree that none of the valves used in a closed center hyd system need a relief in a closed center hyd system.
If the valve does have a relief, just set the valve relief to say 3000 psi so it will never open, and the pump relief will dictate the relief pressure.
You might say how do you do that with the tractor relief set at 2250 psi. Well, when it gets to 2250 psi, just crank it down more about one full turn should work. Maybe use shims if you have to.
/ loader swap
Valve ordered (back ordered)...they said in @ two weeks. I will post an update when I get it. This will give me time to fab the mounting brackets. Thanks for the help guys.
/ loader swap
Update...10gpm valve is no longer available...they are sending me a 25gpm valve. Will that be an issue?
/ loader swap
JJ ...right after I spoke with the tech service rep; I pulled up your post to double check witch valve you recommended. Anyhow I immediately called him back only to get his voice mail. I told him about your suggestions but he did not return my call and I received a notice that the larger valve has already shipped. Guess I will iron it out on Monday.
/ loader swap #19
If you can swap it out with no hassle, do so.
That valve will work, but you will be at full flow at about half lever.
You will not have the finesses if feathering.
A valve matched up to your flow in GPM's is best.
1667 (A57192)
1667 (A57192)
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Iranch IRET13 (A60463)
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
