loader swap
/ loader swap #21
Thanks J_J, I always learn something in your replies. I do not need the knowledge, but will store it in my memory. The trick will be retreaving it!!
/ loader swap
Update...both recommended valves were not available JJ. so I went ahead and mounted the larger control valve . spoke with the vice president of surplus center and he told me that Valve would probably work on a closed Center system . so far so good still have to bleed more air out of the system and do some welding on the brackets I fabricated . hope to finish it up and test it out next week ;thanks to all who chimed in it meant a lot .
/ loader swap #23
Which valve did you end up with, and did you order the closed center plug?
/ loader swap
It was a 25gpm valve and a I ordered a closed center plug for it.
/ loader swap
Just a note of gratitude to JJ, Tx Jim, and all others for your guidance. It has been two long years and several thousand dollars since I first brought home the caseIH 585 with bad hydraulics. That tractor not sits in the back forty with a bushhog. The loader happily resides on my JD 2020. I cannot begin to express the joy I felt carrying two round bales across the pasture yesterday...thanks a million guys.
/ loader swap #26
Thanks for reporting you progress and CONGRATULATIONS.
2015 Chevrolet Express Van (A62613)
2015 Chevrolet...
240 Massey Ferguson Tractor (A61165)
240 Massey...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
3269 (A63117)
3269 (A63117)
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
