loader install
/ loader install #1
mattellis2
Bronze Member
finally bit the bullet, and bought a loader. i was able to pick it up at branson in north ga, and am in the process of installing it myself. by picking it up/doing a self install, i saved about $800.
anyway, i the the complete subframe mounted, the valve plumbed, and the return line installed. the only thing i lack is the connection on the supply side. there are two lines, and for the life of me, i can't find the plugs where these install. can someone point me in the right direction? would a picture be possible (it being worth a thousand words, and all.
thanks a bunch. i'll post pics when i am done. it is the new bl25s. i also took some pictures of some new goodies when i was at branson today...like a new 6640 cab tractor!
-matt
/ loader install
got it figure out, and everything is running fine. i have to put the decals on the loader, then pictures.
thanks all!
-matt
/ loader install #3
Congratulations on your purchase. I'm looking forward to the photos.
/ loader install #5
Recently had to have mine repaired.. the post & arm assembly which attaches to the tractor needed to be re-welded. the post base was evidently not attached tightly to the tractor and caused it to split apart.. just make sure you have the surfaces are absolutely flat, use proper diameter bolts & lock washers and get a strong tight fit...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Wheel Loader Root Rake (A68134)
Wheel Loader Root...
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
2017 Peterbilt 320 New Way 20ASL 20yd. Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
2001 Frieghtliner MT55 Chassis Step Van (A66736)
2001 Frieghtliner...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
