Tires Loaded tires on B2920
   / Loaded tires on B2920 #1
McREBEL
Mississippi
Kubota B2920
I loaded the rear tires of the B2920 with rv/marine antifreeze and water this past weekend. I could tell a difference just driving it out of the carport. It just felt more solid/stable. With some ballast on the back I bogged the engine a little driving in to a pile of composted manure. Prior to loading the tires it would spin before it would bog any. That was in M range. In L it probably will still spin. One of my initial concerns with loading the tires was a negative effect on ride quality. I noticed little to no difference even out on the road at full speed. No sound of sloshing water either. I am glad I did it.
   / Loaded tires on B2920 #2
As an added benefit if you ever get a leak you don't need to worry about poisoning the local critters or your family.
Sent from my iPhone using TractorByNet
   / Loaded tires on B2920 #3
Nice work. Personally, if I had to do it again, I would go with foam.
   / Loaded tires on B2920 #4
Nice. I Have rimguard in mine and it definitely makes a bit difference
2013 Cadillac Escalade Luxury SUV (A50324)
2013 Cadillac...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
UNUSED MOWERKING SSECAG-Y AUGER BITS (A51244)
UNUSED MOWERKING...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
International 844 Tractor (AS IS) (A50774)
International 844...
