Tires Loaded tires on B2920
   / Loaded tires on B2920 #1
McREBEL
Mississippi
Kubota B2920
I loaded the rear tires of the B2920 with rv/marine antifreeze and water this past weekend. I could tell a difference just driving it out of the carport. It just felt more solid/stable. With some ballast on the back I bogged the engine a little driving in to a pile of composted manure. Prior to loading the tires it would spin before it would bog any. That was in M range. In L it probably will still spin. One of my initial concerns with loading the tires was a negative effect on ride quality. I noticed little to no difference even out on the road at full speed. No sound of sloshing water either. I am glad I did it.
   / Loaded tires on B2920 #2
As an added benefit if you ever get a leak you don't need to worry about poisoning the local critters or your family.
Sent from my iPhone using TractorByNet
   / Loaded tires on B2920 #3
Nice work. Personally, if I had to do it again, I would go with foam.
   / Loaded tires on B2920 #4
Nice. I Have rimguard in mine and it definitely makes a bit difference
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2016 Mercedes-Benz GL-Class SUV (A50324)
2016 Mercedes-Benz...
