Linear Actuator for ct120 grapple
   / Linear Actuator for ct120 grapple
I falsely read 200 pounds for 2000 pounds. I think it's severely underpowered now. My grapple doesn't bite hard enough to suit me and assuming it had 2" bore cylinders at 2600 psi that's about 8100 pounds of push. I could calculate it fairly accurately by taking some measurements, but just taking a guess the closing pressure at the tip is about 1/4 that much. I want to build a grapple with about a 4" bore cylinder, but it's not practical because of the strength it would have to be not to self destruct. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=495991"/>
I'm not at that level. The tractor can lift 400 lbs if I can hold the brush I place so it doesn't fall off on the way to chipper it's a win. Also I get your point about the lose of power. I'm getting that form 200 lbs of power I might get 50 lbs at the bucket.
   / Linear Actuator for ct120 grapple #12
I think a brush fork would be better than a bucket with a very weak grapple. I've moved quite a bit of brush with with just pallet forks, but a wider platform would be a lot better. IMO the pallet forks work much better than a bucket for moving brush. I think even something cheesy like 2x4s strapped on the bucket would be a better solution.
   / Linear Actuator for ct120 grapple #13
http://www.tractorbynet.com/forums/showthread.php?t=321704 I've messed with $60 & $160 linear actuators for power SSQA & an automated chicken coop door... Both worked fine for those low torque applications. However for a grapple generally you'll be on the wrong side of leverage getting a fraction of that power. The better actuator I ended up using for my SSQA project wasn't that robust or fast. It was good enough for my SSQA where it could take 10 seconds to latch or unlatch as I drove up or away. But it would be annoyingly slow for a grapple. The mounts are either pot metal or aluminum & would Crack in a few uses. And that was the good 10-15@ actuator. The cheap ones only pull an amp or so.
Great Idea. Once I screw the pooch I can use it for the SSQA
   / Linear Actuator for ct120 grapple #15
As long as you don't break the mounting brackets or burn out the motors on the light actuators. On the final version I put a circuit breaker smaller than the linear actuators max draw in the mix. That way the breaker would pop before the actuator & pins jammed to hard if things weren't lined up.
I really liked that power SSQA setup. I'll probably do it hydraulically on my new L4060 as I have a 3rd function up there now. Will just leave the 3rd function plugged into the SSQA unless I need to hook up an implement, in which case I'll be up there to connect hoses already.
   / Linear Actuator for ct120 grapple #16
If you have rear ports, why not run two hoses up along the side of tractor and loader, to the grapple? That is how I run mine, works good.
I don't have any ports in the back.
   / Linear Actuator for ct120 grapple #18
An electric diverter valve plumbed at your loader hookups, maybe?
   / Linear Actuator for ct120 grapple #19
Maybe an electric winch could be used to close the grapple and a couple of heavy springs could open it?
   / Linear Actuator for ct120 grapple #20
It's a worthwhile investment in your equipment if you are doing this professionally. Either add a rear port and run a hose to the front or put a diverter valve on the curl function.
2017 Ford F-550 Dur-A-Lift DTAX39 39ft. Insulated Bucket Truck (A60460)
2017 Ford F-550...
2022 JOHN DEERE 744L WHEEL LOADER (A60429)
2022 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
