Lifting straps or chains
/ Lifting straps or chains
Don't forget to use USA forged hooks & shackles as terminal tackle. The real lifting gear will all have the manufactures name stamped on it along with their strength & capacity. China/India are not "manufactures" and if so stamped are sure indicators of low quality/counterfit hardware.[/QUOTE]
I saw a report on how bootleg untested weak overseas bolts make their way into our bridges, cars etc...
its scary.
/ Lifting straps or chains #12
My opinion is either is fine as long as they are rated for the load and rated for vertical lifting. Not all all chains or straps are rated for lifting purposes.
/ Lifting straps or chains #13
coolhl7 said:
Which is safer for lifting heavy items with the FEL, straps or chains of equivalent ratings?
most of the "towing" chains I see specifically warn against using them for lifting but I figure that is CYA litigation protection...
all advice appreciated. Thanks
It might seem a strange answer...but here's mine. I prefer chains over straps for LIFTING because even a POS strap costs a lot..and are too easily "damaged"
I use ( this will rock them back on their heels..lol) CHEAP...HF chain..in the 5/16" size ( complete with China hooks...20 feet...$16 on sale...:) And now you ask..WHY?
My rig is only capable of lifting about 850 lbs..and I wouldnt begin to lift that much using the hooks on the bucket! I lift things that I cant begin to phyically CARRY ( thats why I bought it to begin with!!) Am I worried about dropping the load on someone? Nope. First off..its never far off the ground...secondily..for someone to be "under it"...they would have to be scooting along the ground on some sort of "creeper"..!!!
I dont have a boom for my FEL ( although do intend to weld one up) to lift things VERY high off the ground..such as rafter trusses for a small bulding I intend on putting up this year ( I have no idea how much they might weigh...but Ive carried 20 footers on my bare shoulder...and this will only be 14'...so no "biggie there"..AND...no one will be under it anyway!!
Now...would I use the same sort of "chain" from "Hong Kong's Best" if I had an honest to goodness overhead winch or crane or ??.. NO WAY!...:)
/ Lifting straps or chains #14
I use a special made short length of chain for lifting with the loader (dad's old chain from way before we had trade with china). I just don't want to use anything that streaches.
mark
/ Lifting straps or chains #15
Which weighs more, pound of lead or pound of feathers? If they are rated equal, I don't see any difference. Which would be easier? Probably chain. It's hard to get straps around what you are trying to lift and then connect to a lifting device without something sharp coming into contact with strap (unless they have lifting eyes). Being an ex-iron worker, we most always used cable (chokers and spreader bars, etc.). Probably some sailors on here prefer rope. Really depends on job.
/ Lifting straps or chains #16
I agree with the concept that EITHER will work, assuming each has equal load rating and they are USED correctly, stored correctly, and inspected on occasion. Be that as it may, the AVERAGE user doesn't need to sling a load every day. Chains have a lnger "shelf life" over straps if not kept in ideal conditions OR when they get abused or mistreated.
I feel MORE COMFORTABLE with chains. I USE straps on many an occasion.
The contractor I work for has a number of cranes. One is a (Hope I spell this right) Manatowic (?) 200 ton model. I've seen it with a few INCREDABLY heavy loads slung with straps. (also cables or chains) Seems the riggers prefer straps. (Doubtful this crane has ever lifted over 50 tons. It's high lifting capacity is needed to carry a long boom that is often extended out quite a ways in front of the crane.
If you're one who tends to push limits and throw caution to the wind, I'd have to suggest chains. (And someone else lifting whatever it is you're lifting)
/ Lifting straps or chains #17
I'll add my two cents -
I've worked in heavy industrial settings for years as a millwright/welder/rigger and everyone has a preference. One point that I haven't seen mentioned is that wire chokers and nylon slings also have a bit of an "early warning system" built in. By this, I mean that you can see them begin to unravel or fray before they reach their breaking point. Chains do stretch and break but you really don't have time to notice it before they snap/break. Chains are really useful for quick picks, especially when used with grab hooks but have a tendency to slide on solid edges, such as steel beams, columns, or pipe. Nylon slings require extra cushion or blocking (wood or rubber) on solid edges. Heat is also a problem with these slings - they melt - don't weld and then lift!! Wire slings or chokers are probably the most versatile but you need to take care of them to avoid kinks or "a**holes" from lifting objects with solid edges. Use cushions with these as well whenever possible.:)
/ Lifting straps or chains #18
High grade high quality chain is hard to beat. one area I do not skimp on. Straps for lifting low load soft materials.
/ Lifting straps or chains #19
i dont like the way straps "unload" when they break, only dent i ever had in my old truck was from where i was pulling a post and when the post came free it unloaded the energy (the post) into my tail gate. i pulled the one right next to it with a chain, no streach there and no dent. I unladed precious moss covered rock for a customer with straps so i would not scratch them. I tie our dirt bikes down with straps. straps are easy,light, soft and strech. If i had to trust my life to one of the 2 i would chose the chain. just my thoughts
/ Lifting straps or chains #20
When dealing with a shock load, such as pulling out a stuck vehicle we always use nylon in the rigging. Our minimum size is 5/8 for light loads but most often 1". If lifting from the bucket then I use chain because I can vary the length just by moving the hook. (the nylon rope ALWAYS goes on a clevis or other smooth surface). The only time we ever use plastic "tow ropes" is for really light jobs such as a stuck ATV.( now and then I will haul out my two 100' sections of 3/4" plastic for a long pull on a dead moose or skidoo out on the lake or swamp where I can't get close enough for the winch cable to reach).I also use rope to guide trees that are liable to fall in embarrassing directions.
In ever case we always make sure that the SWL of the rope, chain or strap is well over the weight of the load.
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
296385 (A57192)
296385 (A57192)
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
iDrive TDS-2010H...
2018 Merlo TF30.9 115 (A60462)
2018 Merlo TF30.9...
