LB1714 Thermostat
/ LB1714 Thermostat #1
DunbarDave
Kioti LB1714
I have a Kioti LB1714 (1988 - first year of production). I require a new thermostat but having trouble sourcing. The old thermostat has a flange of 38 mm and post of 27 mm. Searches return part #s that are larger - probably for later model years. Any information would be appreciated.
/ LB1714 Thermostat #2
Have you checked with your local Kioti dealer or taken the actual thermostat in to an auto parts store?
/ LB1714 Thermostat #3
You would need number E5205-73011A. Your local Kioti dealer should be able to order it for you.
/ LB1714 Thermostat
Dealer is looking into it for me. Good idea to take it to store to check. Thanks.
/ LB1714 Thermostat
Great information. Thanks so much!
It seems that the part # is for a thermostat kit. Do you have an idea of what the kit is? Thermostat & gasket - or other pieces, possibly?
/ LB1714 Thermostat
Here is a pic of that assembly - contains all pieces from the rad to the block.
/ LB1714 Thermostat
I just needed the 38mm thermostat. Googled and found an equivalent from Kubota.
Part #s are: Thermostat - 1E399-73012 and gasket - 16264-73270.
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
