LB1714 Thermostat
/ LB1714 Thermostat #1
DunbarDave
Kioti LB1714
I have a Kioti LB1714 (1988 - first year of production). I require a new thermostat but having trouble sourcing. The old thermostat has a flange of 38 mm and post of 27 mm. Searches return part #s that are larger - probably for later model years. Any information would be appreciated.
/ LB1714 Thermostat #2
Have you checked with your local Kioti dealer or taken the actual thermostat in to an auto parts store?
/ LB1714 Thermostat #3
You would need number E5205-73011A. Your local Kioti dealer should be able to order it for you.
/ LB1714 Thermostat
Dealer is looking into it for me. Good idea to take it to store to check. Thanks.
/ LB1714 Thermostat
Great information. Thanks so much!
It seems that the part # is for a thermostat kit. Do you have an idea of what the kit is? Thermostat & gasket - or other pieces, possibly?
/ LB1714 Thermostat
Here is a pic of that assembly - contains all pieces from the rad to the block.
/ LB1714 Thermostat
I just needed the 38mm thermostat. Googled and found an equivalent from Kubota.
Part #s are: Thermostat - 1E399-73012 and gasket - 16264-73270.
