LB1714 Thermostat
/ LB1714 Thermostat #1
DunbarDave
Kioti LB1714
I have a Kioti LB1714 (1988 - first year of production). I require a new thermostat but having trouble sourcing. The old thermostat has a flange of 38 mm and post of 27 mm. Searches return part #s that are larger - probably for later model years. Any information would be appreciated.
/ LB1714 Thermostat #2
Have you checked with your local Kioti dealer or taken the actual thermostat in to an auto parts store?
/ LB1714 Thermostat #3
You would need number E5205-73011A. Your local Kioti dealer should be able to order it for you.
/ LB1714 Thermostat
Dealer is looking into it for me. Good idea to take it to store to check. Thanks.
/ LB1714 Thermostat
Great information. Thanks so much!
It seems that the part # is for a thermostat kit. Do you have an idea of what the kit is? Thermostat & gasket - or other pieces, possibly?
/ LB1714 Thermostat
Here is a pic of that assembly - contains all pieces from the rad to the block.
/ LB1714 Thermostat
I just needed the 38mm thermostat. Googled and found an equivalent from Kubota.
Part #s are: Thermostat - 1E399-73012 and gasket - 16264-73270.
2006 Vermeer BC1000XL Chipper (A61166)
2006 Vermeer...
TAKEUCHI TL12R2 SKID STEER (A62129)
TAKEUCHI TL12R2...
2011 PJ Trailer T/A Tilt Trailer (A61569)
2011 PJ Trailer...
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
2013 John Deere 329E High Flow Compact Track Loader Skid Steer (A61567)
2013 John Deere...
2012 Jeep Patriot AWD SUV (A61569)
2012 Jeep Patriot...
