Lawn Tractor vs Zero Turn
/ Lawn Tractor vs Zero Turn #81
I am repeating a story here that I have posted several times before. Just not on this thread.
When I bought my Bad Boy mower I first ordered one with a Kohler engine and the 60" deck which was the widest possible on that frame. As I was walking to my truck the dealer's daughter stopped me. She had graduated High School with my youngest, was on the yearbook staff with her, and spent a night or two at our house with the rest of the yearbook staff. She was the dealership's secretary.
Anyway.
She told me to not get the 60" deck but to get the 54". Said that everybody who got the 60" on that frame complained about the mower scalping their yard at every uneven spot. She explained that the deck stuck out too far on the left side. And, she said, take the money you save by getting the narrower deck and get the Kawasaki engine instead of the Kohler. It will burn less gas and, she looked over both shoulders to make sure nobody was listening, we don't know how to work on them because we never have to work on them.
I changed the order to what she said.
Couple years later a friend me that he had traded his Bad Boy mower off because he was continuously scalping his yard. I asked and sure enough he had the same frame but the 60" deck. I have owned mine now for about twelve years?? or so. At one time I was mowing five or six yards a week for a total of about eight acres. Now I'm down to just my one acre. Have been completely pleased with the mower.
Points of this story, first, don't get the widest deck available on a particular frame, you will end up scalping your yard if it is very rough. Second, get the Kawasaki engine. Third, when you are in your late fifties and a drop dead gorgeous blonde twenty something gives you advice you take it.
RSKY
/ Lawn Tractor vs Zero Turn #82
No disagreement on the diesel lasting longer. A diesel will outast most of the components on the mower.
Which is why I prefer gas, you're not paying for something that you're not going to even utilize. Unless you want to rebuild the mower around the diesel engine which is certainly feasible.
For this OP diesel is way out of his price range.
/ Lawn Tractor vs Zero Turn #83
Anyway.
RSKY
Funny, good story I agree on the Kawasaki.
Here's my Kawasaki experience we bought a little John Deere 170 in early 1990s. Had the 14 horse Kawasaki. I mowed my two and a half acres loaned it to my pastor who mowed his 3 acres many times mowed several Church yards with it.
It didn't have an hour meter but I sold it in 2000 with countless hundreds and probably thousand hours plus. Never had a minutes trouble from it and it still ran like a top when I sold it because I needed something bigger for my five acres.
A JD 170 is a lawn tractor but I used it all those years as a garden tractor.
My neighbor had an exmark with the commercial Kohler on it. I mowed with it a handful of times while he was unable to. I could tell a difference in the less torque and performance from my Kawasaki ZTR I was mowing with at the time. Though the Kohler was quieter
/ Lawn Tractor vs Zero Turn #84
My F-935 JD front mower has features of both: Front deck, side and rear discharge decks, can run other attachments (broom, snow blower, plow, leaf blower, PTO generator, etc). It has a steering wheel, goes fast, diesel. My 76" offset deck sneaks under my pine trees so I don't get my glasses swiped off. Hooks up to my Woods Vac trailer when I use the 72" side discharge deck. Sips fuel and is quiet. Many tire tread varieties for hills and traction. Mine is 2wd, but an 1145 is 4wd. Used ones around here go for about $2500 to $3500, depending in version (# of fuel tanks, 1 vs. 2 hydraulic outlets, gas or diesel, 60, 72, 76" deck). Easy to do maintenance on. My twin-post lift makes blade sharpening easy plus it also serves as storage up in the air when not in use. It's pto speed is 2200 and with a deck mounted gearbox reducer with a 540 spindle on it, I run a Winco house generator and a water pump when necessary.
/ Lawn Tractor vs Zero Turn #85
Anyway.
RSKY
Good story! I disagree on the scalping part though. A 54" will scalp as easily as a 61" and if you are scalping your lawn you are mowing way too low. Mow high, mow often. Jut my opinion though
/ Lawn Tractor vs Zero Turn #86
Anyway.
RSKY
Everyone wants to get the widest mower they can but fail to realize this. Scalping and you my have to fir between things. My 48in hardly fits in between some things in my yard.
/ Lawn Tractor vs Zero Turn #87
None of the gas powered ones are even remotely fuel efficient from my personal experience (we have 2 zero turn mowers, one with the Kawasaki and one with the Kohler vertical V twins). Only way you'll get fuel efficiency is with a diesel unit. Our F20 Kubota front mount mower (very similar to a Grasshopper) runs and runs on a tank of diesel where as the gas powered ones suck it down.
I'm gonna sell one of the Z's simply because the F20 with it's front mount deck, you can mow under trees and fence lines but with a mid mount deck, that is an impossibility. No scalping issues here, flat as a board. The F20 has a 72" deck, 3 blade, drive shaft powered, so no belts to wear out either and like a Grasshopper, you can tilt the deck up almost vertical for blade changes and cleaning the wadded up grass off. Makes that a simple operation. leaving wadded up grass on the underside of any deck will eventually cause it to rust out. Finally, the F20 has a steering wheel and not the 2 'oars' which I also like better and you can get the F series Kubota in either 2wd or 4wd and they are hydro's. I got mine in 2wd as I don't need the 4wd at all for mowing.
They ain't cheap by a long shot but then no diesel powered anything is cheap today.
/ Lawn Tractor vs Zero Turn #88
Agree! My gasoline mowers do use a lot of fuel. I also have a 72" belly mower on my Kubota B series and it will mow for days on a tank of diesel. Big difference.
/ Lawn Tractor vs Zero Turn #89
Yes, this is exactly a concern of mine.
Right now my gf likes "mowing" the pasture, but she'll only do the flat parts of it, and at about 1mph :). I then do the hilly/uneven/parts with trees.
I'm a "research first" type person to find the "optimal" set of choices to decide between in person, but you're right that it may simply come down to whether she's comfortable with a ZT vs a garden tractor.
My 78 year old MIL operates both our commercial Zs. One is an, out front deck, grasshopper 725Diesel and the other is a, mid-mount deck, bush hog with a big Kawasaki gas.
You can mow the 11 miles an hour with the Kawasaki (and I do). You can know about 7mph with the grasshopper. That isn't a limitation of the diesel engine but of the grasshopper ground speed.
MIL mows her 2 acres herself, most of the time, with one or the other.
@5030 is not wrong about the fuel efficiency of diesel over gas. However, the payback period to recover the $4,000 difference will buy you a LOT of gas.
/ Lawn Tractor vs Zero Turn #90
The fuel savings begins to be a factor in my light commercial use of 500 hours per year. Rough numbers, I'm saving about $1300 per year in fuel costs by running diesel mowers.
/ Lawn Tractor vs Zero Turn #91
The mower I own is one of Bad Boys narrower frames. That is why is will scalp on a rough yard with a wide deck. The wider the distance between the front wheels the less likelihood of a mower scalping.
But I agree with you about the mowing high and often. People walk by our house all the time down our quiet road. I have many comments from people about how our yard is the best looking in the neighborhood. When asked I tell them that by June 1st I am mowing as high as the deck will go. Do the same and your yard will look like ours. Then they go home and cut theirs 1" tall.
RSKY
/ Lawn Tractor vs Zero Turn #92
Sounds like the guy across the road. Cuts it short as heck, makes cud too. Looks terrible, guess he likes wasting expensive gasoline.
/ Lawn Tractor vs Zero Turn #93
I don't have a big problem with scalping, but like you I have enough obstacles in my yard that any time saved on open spaces will be spent hand-mowing between/around rocks, bushes, wife's flower gardens, etc. In fact, a 42" is about as wide as will fit thru a couple of those spots. A ZTR would be nice for the maneuverability but I don't think anyone makes one that narrow.
/ Lawn Tractor vs Zero Turn #95
Kubota has a 42" deck ZTR.
/ Lawn Tractor vs Zero Turn #96
I'm renting my neighbors cabin while building my cabin. She asked If I could mow the yard. She has an older Grasshopper ZT. I'm not a fan. It's an older one sans rollbar and not a good feeling on side slopes. Plus you have to keep both hands on even in a straight line. Hard to drink a beer in that situation....I'm kidding.
/ Lawn Tractor vs Zero Turn #97
You just don't have the right equipment. :D
/ Lawn Tractor vs Zero Turn #98
RSKY
So true about cutting height. I likely don't cut quite that high, but my fescue lawns get cut at 3.75 - 4.00" . Customers are constantly asking that I cut lower, and it drives me crazy. I drew my line in the sand this year with a few lawns at 3.25" - any shorter they can hire someone else.
Intersting twist thrown into the decision yesterday. Turns out not many mowers are made for a 5' tall woman...
The Kubota 400 series has the parking brake at the front of the deck, which even with the seat all the way forward she struggled to press. And of course the armrests interfere with the lap bars if the seat is all the way forward (can't get into neutral/reverse).
Kubota 200 series has a knob/lever for parking brake so that's not an issue. So this is still in the running, though I'm a big concerned about the lower profile tires (22x10-14).
The Cub Cadet ZTS2 has a similar issue - with the seat all the way forward, she struggles to use the 'gas' pedal. So as much as I like the front-wheel steering and the steering wheel vs lap bars, I'm not sure these will work (plus I'd have to buy the ZTXS model sight-unseen).
I do like that the cub cadet with lap bars applies the parking brake when you push the lap bars into neutral (out to the side). it's nice not having an 'extra' step to apply the parking brake, if you're going to be getting off and on to clear out rocks/debris. The 22x12-12 tires seem better for our rougher property.
If I'm going with a standard ZT with lap bars, starting to look at the Gravelly ZT HD-52 as an option. Sadly it doesn't come with ROPS -- I know the Pro Z does and has a lot more to offer, but I think it is outside our price range.
Walnut Picnic Table (A66408)
Walnut Picnic...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
HD Round Bale Feeder (A66408)
HD Round Bale...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
