Laser Burning Question
/ Laser Burning Question #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I don't know any machinist forums to post this too so here goes.
Anybody had any experience with burning 5/8" tap drill holes in 1/2" plate steel with a NC Laser. Does the material in the heat zone micro harden so as to make tapping very impractical? I can have it burned slightly under and then run a drill through but it will drive the labor cost sky high.
/ Laser Burning Question #2
How 'bout waterjet instead. It's not as precise but you have no heat affected zone.
/ Laser Burning Question #3
Might give Barrry a call here. He is a great guy, and very, very familiar with lasers etc. There are a couple laser specific forums as well, although I am not familiar with them.
Introduction
/ Laser Burning Question #4
I was not aware that laser cutting was availabe for plate that thick.
In my experience it has be limited to thin gauges.
Most "patern places" (custom machine shops) use a water jet in these parts. The precision on water jet should be sufficent for a tap operation depending on required % threads.
/ Laser Burning Question #6
Afternoon shaley,
If the material is CRS plate low carbon there should be no problem laser cutting the plate. Obviously you need a machine that can handle 1/2" plate but not a problem ! There should be no hardening issues so therefore no tapping issues either !
If you are trying to do the same thing on alloy material then you potentailly can have problems !
As the others have suggested, waterjet is a viable option also, but not as accurate as laser. I have been a toolmaker the past 35 years but most all of that type work we subcontarct. Hope this helps answer you question.;)
Thanks Guys,
I'm trying to make some wheel adapters out of A36 PL. If I can keep the machining to just one machine operation it will keep my cost down. The Laser company I spoke with says 1" max for there machine.
/ Laser Burning Question #8
Waterjet is the way to go. At work we have used it on 1" nickel chrome plate which is very hard to machine and it did a very good job.
/ Laser Burning Question #9
Shalley
I used to do some computer work for a company that did waterjetting. They would rough cut parts to within .01 in. and then send the parts out for finish machining. When I moved they were upgrading to what they hoped would be .001 in accuracy. Would that be accurate enough?
/ Laser Burning Question #12
Depends on how many holes you expect from each tap. If this is going to be an ongoing production process, I don't think it would be practical. If you're going to tap a few holes and then you're done, it could work. If you keep a CO2, Argon, or nitrogen blanket on it while it's burning, you can avoid some of the abrasive scale.
/ Laser Burning Question #13
I've been in the laser cutting business for awhile.
I'd say with 1/2 inch plate and 5/8 holes, which is about M14 in metric, the cut will be rough. Lasers cut rough due to the heat put into the material when cutting holes with the same diameter as the plate thickness.
Are you talking lots and lots of holes ? Then either use the laser to precisely engrave the center of the hole and then drill and tap (and save on laser time because spouting a start hole costs as much time as making a 2 feet cut) or laser a hole that is 2mm smaller than what needs to be tapped, and use a tap drill. I dont know if you can get them in that size, or in imperial sizes, but it is a tap with a drill up front. we used them all the time.
/ Laser Burning Question #14
I am wondering if this is a couple of wheel adapter's for his tractor or is he fixing to start a manufacturing line of them?
If just a couple, heck mark them out, send them to me and I will drill and tap them. If your starting a business, I am not the one you need to talk to.
David from jax
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
Skid Steer Drag Ripper (A65640)
Skid Steer Drag...
