l3400 HST power questions
/ l3400 HST power questions #1
grizzjeeper
Fairfield Maine
Kubota l3400 HST
My l3400 HST seems low on power, I guess I am looking for some reasurance. There are plenty of times when I could easily stall the engine in Low range at pto throttle doing loader work. I feel that with 34 HP I should be spinning the wheels. The terrain is usually a mud/clay with a fairly hard bottom. I am glad I didnt get a smaller unit.
Is mine underpowered? Seems like it has less power now then when I first got it. 33 hours on it now.
/ l3400 HST power questions #2
I have an L3400DT, so I can't compare it to the HST, but I don't have any power problems as you describe. I will lose traction before I would stall... I can push a lot of dirt at 2000rpm, and it still has plenty of power.
Sounds like you might be having a problem, especially since it seemed like you had more power when it was new...
/ l3400 HST power questions #3
Hello grizzjeeper,
This is typical of a hydro tranny. You may want to try a toothbar to help the loader work. MJK
/ l3400 HST power questions #4
If your trying to dig up unbroken ground then yes it will be easy to stall the motor.
40ft High Cube Shipping Container (A64553)
40ft High Cube...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
PALLET OF 14.9-24 TIRES & WHEELS (A64278)
PALLET OF 14.9-24...
2024 Ford Explorer AWD SUV (A64557)
2024 Ford Explorer...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
