L2800 Hydrostat Whines
/ L2800 Hydrostat Whines #1
DanielTerence
Kubota L2800
My new L2800 arrived yesterday. The hydrostat makes a high pitched whining noise whenever there is the least bit of a load on the engine. Even going up a slight incline will do it. I have an FEL and 5 ft brushhot attached to it. Is this normal? Too much weight?
Thanks.
/ L2800 Hydrostat Whines #2
I've got a L3400 that makes the same noise. I believe it to be normal. I think it is just the hydro pump doing the work. You might increase your rpm's a little and see if it is the same.
/ L2800 Hydrostat Whines #4
My L5030 HSTC also whines at high RPMs, particularly under load. I believe this to be normal for hydrostatic transmissions. I consider it to be a good thing... means I'm actually working instead of running around.
/ L2800 Hydrostat Whines #5
A certain amount of whine is normal for the hydro units. I really didn't realize that mine was making the noise until I had the hydro fluid replaced at 50 hours with super UDT. That made it like a new tractor. It lowered the noise by a huge amount. The Deere and CNH units I've test driven also made the same noise. I wouldn't worry any.
/ L2800 Hydrostat Whines #6
Since we can't hear it, it's hard to say whether it's the same whine /forums/images/graemlins/wink.gif but both my B7100 and my B2710 hydros had a whine that I wasn't accustomed to in straight gear transmissions, so I sure suspect that yours is normal.
/ L2800 Hydrostat Whines #7
Drago
I had the same experience on my L3130. The dealer had used NH hydro/tran fluid when he set it up. I changed to SUDT at 50 hours and every thing quieted down. Almost no whine. I did notice a little more leak down on the hydraulics however.
Vernon
/ L2800 Hydrostat Whines #8
That's part of the reason I bought an L4400, gear drive. I didn't think I could put up with a hydrostatic whine the rest of my life. But I'm sure you get used to the noise, or the fluid might be the cause.
simonmeridew
/ L2800 Hydrostat Whines #9
My L2800HST whines also, I think it is the nature of any Hydo tranny.
/ L2800 Hydrostat Whines #10
<font color="blue"> I didn't think I could put up with a hydrostatic whine the rest of my life. </font>
I'm glad that I'm not the only one that thinks that. All of the hydros that I have ever driven have had that irritating sound. I couldn't live with it. I would like to drive one with SUDT and see if it really makes that much difference. I know that my gear tractors are real quite most of the time and that is what I like.
/ L2800 Hydrostat Whines #11
My B3030 has a lot of hydro whine in high range, almost none on low & medium. The dealer says it's normal?
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2159 (A65055)
2159 (A65055)
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2022 Ford F-150...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
