Kubota or John Deer
/ Kubota or John Deer #101
Actually just saw on a farming show this morning....26 h.p. and under tractors hold a 35% market share of ALL tractors sold.
I guess they must be real tractors? LOL
I use a cheap battery pump that inserts into the fuel canister. You will still need rest the fuel canister on a tall bucket so the hose will reach the fuel port on the tractor.
Battery Pump
Yeah I have already decided to buy one of those 100 gal truck tanks with a 12v pump and hose setup. I used to have one of those when I had heavy equipment to work with. I also looked at those plastic gas caddys that hold around 30 gals. The only problem with that is my fuel man won't just bring 30 gals out but he will for a 90 to 100 gal order. Also I can just leave it in one spot and not have to figure out how to elevate it to put fuel in the tractor.
/ Kubota or John Deer #103
' Yes My Long term concern would be with the factories piston choice for Turbo / Non Turbo applications of the same Cubic displacement diesel engine.
That is what the FRED ran into with his Kubota Turbo upgrade conversion.
It ran Great for a while until it beat the piston ring lands out and then lost some compression.
Once he sourced the factory Kubota Turbo pistons that employ piston steel ring land inserts, all was well other than having to tear the engine down to replace the Normally aspirated pistons and rings.
Pure speculation as to the reason why FRED’s machine failed after 400 hours.
He made his own fueling adjustments and shockingly wasn’t monitoring any engine diagnostics or EGT temperatures. The likely scenario was run away combustion temperatures which lead to his pistons failing.
I don’t know his background or qualifications but, I’m not surprised it failed.
Mike
/ Kubota or John Deer #104
Why would I even consider that? Not at all suited to what I do. Mine are large enough and I can actually turn them in a field, unlike that behemoth that needs a football field to change directions. In the grand scheme of things they might be a weine but that weinie is large enough to do what I need to accomplish.
That’s not what she said !
/ Kubota or John Deer #105
I hear ya. I got nothing against the guy, don't even know him, but like you say it gets tiring. If you hate small tractors so much why do you read all the small tractor threads, then have to tell us over and over again "I have no use" and "they are not real tractors"
5030 is my #1 on my ignore list. Makes perusing threads much more pleasant.
/ Kubota or John Deer #106
Mike
OK that is Fair.
That does Not change the Fact that Kubota (at least in some engine sizes)
absolutely demands and specs a specific Turbo piston if used in their engines utilizing a turbo, even if it is possible Kubota uses lower boost than what your kit "may.".
If the engine were vetted on durability by running the engine for at least a couple thousand hours under load and boost the NA pistons are likely up to the task. 500 hours is barely broken in
I have no problem with Folks that want to add this Kit
Just worry about the durability if Kubota does have a different set of pistons available specifically made for boosted applications.
Maybe they only use one piston in this engine bore stroke configuration and it is more than up to the boost.
That is how Ford did it in the 1960's and 1970's
They used a steel insert top ring land on All the 2000-6000 series engines pistons,
Even the carbed gas ones.
If at 1000 hours these kitted tractors lose compression and need repaired.....
It wont be as simple as just removing "the kit". to restore the tractor to kubota operating stock condition.
The head and pan have to come off etc.
I Do Hope that the engines perform well long term.
Heck if I had this model and thought it was low on power I likely would want a kit myself.
/ Kubota or John Deer #107
Mike
I wouldn’t even consider slapping a turbo on an underpowered machine. Maybe it works great but maybe the engine or any number or driveline parts can’t handle the additional power. And it’s more expense and effort than I’d want to put into it. I’d much rather buy something that’s up to the job I’m expecting.
/ Kubota or John Deer #108
And, that is why research and an understanding of the tractor and drivetrain is mandatory. The application is key, there is no “one size fits all” solution. I certainly wouldn’t throw a Turbo on “any” tractor.
The L2501, is unique that it shares its PTO train with its more power L Series tractors and is the perfect candidate for a Turbo system.
I can’t speak to any other tractor application or “backyard” Turbo system until I have thoroughly vetted it.
Mike
/ Kubota or John Deer #109
OK that is Fair.
And this is the problem. You’re grouping all tractors, all engines and all applications together. Each application is unique.
The L2501 and the D1703 engine and variants are well suited for a Turbo system. The engine and Turbo system should last thousands of hours assuming the user properly tunes the tractor, maintains it, and monitors the engine diagnostics along the way.
Mike
/ Kubota or John Deer #110
He's been doing it for years and it gets old.
If I need a bigger tractor I'll buy one. But I don't !!
My weinie tractor does everything I need it to do.
A 90 HP utility tractor can be used for haying but most people doing very much of it start with a tractor of around 130 HP and can go up to 250-300 HP if they are running a triple disc mower. It would be too small to run a Discbine or a silage baler, and a lot too small to run a larger disc mower setup or a large square baler. You also aren't likely to be able to keep up with the cool kids running 10 MPH with a 10' 3 point disc mower in decent hay with only 90 HP either.
I was also wondering how long people would keep misspelling "weenie."
iu
/ Kubota or John Deer #111
Gee
You mean just like the CUT and SCUT models many members use that do just what they want and need that you continually call weinie tractors
I have the perfect size tractor for anything I need to do on my property.
To me, his tractors are weenie tractors. lol
/ Kubota or John Deer #112
iu
Don't include me.....that's why I put it in apostrophes spelled that way.
I have a grade 8 edumacation. LOL
Well run into my frist little problem. So far I have logged 22 hours on my new ride and yesterday light's started flashing and at first I didn't know what was about to happen. Seems like it had a fur ball and needed a flushing. I stopped and pulled it up onto the concrete set the parking break and pushed the regen button. after a second or two the rpm's came up to around 1400 rpms and I let it sit and run hoping it would do it's thing but after a hour I said the heck with it and went into the house. this morning I called my salesman to hoping I could get some insight and right off the bat he told me the problem was that I was babying it too much and needed to always run the tractor up into the pto range. I said that's all and good but what do I do about all these flashing lights. He asked if I had read the owners manual and I told him, well a little. I looked over the part about the regen process and I did what I thought was what it said to do. This afternoon I started it back up and the lights were still flashing so I pulled it back up onto the cement pad and started all over. The same thing, hit the button, rpms came up and it sit there for over an hour, buy the hour meter I might add and nothing. I said what the hell, I opened her up WFO and it sit there another 45 minutes with the same results. I've been around tractors all my life and this is new to me. Anyone have any suggestions other than take it back to the dealer.
/ Kubota or John Deer #114
Run it hot. Even when you're just messing around, doing loader work, you run it hot. These new machines have to be run at a high RPM or the foolish DPF system excretes a brick.
/ Kubota or John Deer #115
OP, if the salesman isn’t offering much assistance, call the service department. They should be able to walk you through the process to get the lights off the dash and the tractor running properly.
Mike
/ Kubota or John Deer #117
Personally, I'd be taking your last suggestion. Good for trying it out, but if it doesn't work for you then return it and go find an older, more user-friendly machine. Running an engine flat out so that it pleases someone else isn't on my agenda.
I enjoy running our quiet tractors. Having them is a enjoyable luxury - not a requirement. Working on our land with the tractor purring at an idle is part of what we enjoy about a rural lifestyle.
Running a machine screaming at PTO rpm all the time is not something that I have any interest in supporting. It is expensive, annoying, and inefficient. Manufacturers and engineers who want our business should get off their duffs and quit being lazy.
rScotty
/ Kubota or John Deer #118
I looked at those two brands, and ended up with a Kioti.
Deere dealer had a take it or leave it attitude. Kubota had an old fashioned, uncomfortable treadle pedal for hst controls, an uncomfortable loader joystick, and seemed to have a larg, uncomfortable transmission hump.
Kioti was an unknown to me at the time, but had a dealer I quickly became comfortable with, a good price, and was conveniently located.
My tractor is several years old now, with no problems.
/ Kubota or John Deer #119
The name badge on the tractor makes no difference to me, i`m not suckin up to any brand. Tractors are like wimmins, they all have their issues and drama.
What is important to me, is dealer support. If the dealer sucks, so won`t a broken tractor that you can`t get parts for, or good tech`s to fix it right, the first time.
The scary part is, seeing all the turn-over of employees within a dealership. May want to talk to a few that actually work on the tractors in these shops too.
My thought process is, who is going to know more about the tractor than those who actually have to "work" on them. They could tell you alot about problems they see.
Ask them how long they`ve worked on the brand, years experience, actually hands on repairs. I bought a Kubota this time around, and ZERO problems or regrets.
Look around in the repair area. Is it kept clean. Is their a young kid with a brand new shiny toolbox that is still wet behind the ears?
Lots of things to consider other than just the brand name of a tractor. Sometimes, we get what we pay for.
/ Kubota or John Deer #120
I only have a hobby farm with about 6.5 acres.
Came from a much larger fruit farm so I still have two Masseys. High hour one has about 800 on the clock.
I was looking at updating the herd recently even though nothing is wrong with the current ones.
Just an itch for something new.
First the prices have gone crazy.
Secondly I don't want to deal with all the new emission controls bullcrap.
For a machine regularily exposed to heat, dust, dirt, electronics are not their friends.
I'll hang on to my old boys, they only get about 70 hours annually combined, and pollute the planet for future generations.
How you are reducing pollution by adding fluids and running them at hi rpms while it stands there doing nothing boggles my mind.
