Kub L3430- New tractor buyer
   / Kub L3430- New tractor buyer #1
GrantSebaugh
Missouri
L3830 w/723 FEL
This site is awesome....have read most of the posts and everyone takes pride in helping. Here's my question and info. Never owned a tractor. I do have a Kubota Z18 mower that really is a great machine. I have 15 acres- 10 wooded other 5 scrub cedar. I'm looking at getting the L3430 with HST and the LA 723 QA with toothbar and 2 sets of rear remotes.
I have dealer quoted $22,500. They priced a Land Pride FDR2584 Finish Mower $2,300 and a BB1572 box for $700.
Haven't shopped NH or JD because I like Kubota and have a dealer close by....problem is I think he is on the high side on both the tractor and implements.
I value your opinions....Grant
   / Kub L3430- New tractor buyer #2
I'm not any kind of expert or anything but that does sound a bit rich. If you have any other Kub dealers within, say 50 miles of your place, you might like to gin up some friendly competition for your business by shopping around.
By the way, that sounds like a great package you're looking at. Best of luck!
   / Kub L3430- New tractor buyer #3
When I got a quote for a L3430 last spring it was $22695 with LA 723 QA, turf tires and 3 remotes. No tooth bar. Your price is very close to that. I consider this a good price for my area.
For reference a 72" MMM and Mid PTO was $3100.
   / Kub L3430- New tractor buyer #4
I paid $26,300 for a similar setup two years ago, except mine has a cab and single remote. Cab was $5000 and extra remote is $500 or $600. With two years of inflation, your deal sounds pretty good to me.
OrangeGuy
   / Kub L3430- New tractor buyer #5
Don't know your location.... but, that's a good price here in Tidewater Virginia...
Similar setup was 22,500 last year when I bought mine.
Pete.
Yes...you might be right. Maybe a little haggling is in order with a couple other dealers.
Thanks Ron....question....3 remotes...how would you be using those. I just want to make sure I outfit it right the first time.
Thanks....Grant
Hey OrangeGuy,
Thanks for the verification...sounds like I need to haggle with a couple dealers.
Thanks...Grant
Thanks Pete....how would you set yours up?
   / Kub L3430- New tractor buyer #10
On my B2910 I have 3 remotes.
1. Front grapple or angle on front snow blade.
2. Rear Tilt.
3. Rear Top cylinder.
When using my rear blade I will have Tilt, Top, and angle hooked up at same time.
Purchasing 1 remote has the highest cost. Adding second and third remote if I remember correctly is less than first. Total for three was $1500.
   / Kub L3430- New tractor buyer #11
Grant... Mine has two remotes, normally for the top and tilt cylinders. (T/T is important).
I run a used 6'Gannon boxscraper on the back most of the time and also have a 6 'BushHog 70-06 back blade with hydraulic offset/angle running off the top link remote. The normal recommendation is a 7' backblade, but the 6' is handier in the tight woods here. Being able to offset makes a big difference too. I run a 5' Bush Hog Razorback cutter (left over from a smaller Kubota) and it would have no problem with a 6'. The quick attach on the FEL is absolutly a must. I have a set of 48" pallet forks for it that I use more than the 6' bucket. I recently bought a toothbar from Markham also their 3pt adapter for the QA... this lets me use a 6'york rake, boom pole, a small 4' boxscraper, and a 30" pond scoop on the FEL. Haven't gotten a chance to run my back blade there yet, but I don't anticipate any problems (just longer hoses)... the 723 loader is awesome. A third remote would be handy and I plan on getting it later ($450 from Kubota).
Hope this helps
Pete.
   / Kub L3430- New tractor buyer #12
Grant... Added info.... HST and unloaded R-1 tires. I plan on foaming them later, probably after I get my first flat from the thorns around here. I went with R-1's due to the wet hillsides (they don't side slip as easy) and need the extra traction in the woods.
Pete.
Pete...this helps me a lot in trying to figure out how best to equip the new tractor. Some stuff I will be able to wait on since this is a lot of money upfront. I know I'll add more stuff later.....man this could get to be a never ending process!!!
   / Kub L3430- New tractor buyer #14
This tractor thing... It's a lot CHEAPER than therapy sessions.
I started years ago with an 8N, my bushog, and a boxscraper. Things just seemed to follow me home after that (camel's nose).
Pete.
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2015 FREIGHTLINER...
12' CONTAINER (A52706)
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
