Kohler Engine
/ Kohler Engine #1
Mike Pa
Exmark Lazer Z
Good afternoon!
I Was looking for some advice on a Kohler 27 HP Commercial engine.
Symptoms:
-Using 1/2 Qt of oil in two hours and fouling the plug on the #1 cylinder.
Repairs:
-Pulled the head and found a burnt and broken exhaust valve. Replaced the exhaust valve, head gasket and all the breather components.
The engine is still fouling the plug a bit and there is still excessive crankcase pressure?
Thanks!
/ Kohler Engine #2
Good afternoon!
Symptoms:
Repairs:
Thanks!
What caused the valve to break? What did the valve guide look like? Did you relap the valve seat. Is the return oil passage from the valve spring cavity to crank case open? Could be filled with carbon caused by the burnt valve.
Did an oil ring go bad? Possibly the spring tension device. Won't effect compression but will sure make them smoke. Only way to tell is to pull the piston.
Roy
/ Kohler Engine
Roy,
Im not sure what caused the valve to break, but it had a nice chunk out of it on one side. The valve guide looked good and with very little play. I did take my time and lapped the valve seat on the new valve. The oil passages were clear.
I originally thought the breather was causing the problem and replaced all the components including the hose to the carb.
Thanks for your response.
2018 Nissan Pathfinder SUV (A64557)
2018 Nissan...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2022 MERCEDES SPRINTER 2500 S/A CARGO VAN (A67147)
2022 MERCEDES...
UNUSED JCT 2 PRONG BALE SPEAR (A65055)
UNUSED JCT 2 PRONG...
2017 TAKEUCHI TB260 EXCAVATOR (A65053)
2017 TAKEUCHI...
JOHN DEERE HX15 BATWING ROTARY MOWER (A64278)
JOHN DEERE HX15...
